Transmission Fluid Leaking from Dipstick
Long-time reader of these forums, they've been super helpful in building 1.5 Skoolies (thank you!). Close to finishing up the second one and ran into a problem that I can't seem to find information on. Hoping the experts on here could help.
Bought the bus 2 months ago, had it checked out and fixed up as needed, nothing major. No transmission issues. Drove it 90 miles home, a couple times locally and had no issues. It's been sitting in my driveway for 2 months as I've fixed it up.
The other day I started it up to move it in the driveway, did so, and then when I put it into neutral and shut it off, a good amount of red fluid came out of the top of the transmission dipstick tube (which was ziptied). I tried again today, letting it run for 15 minutes and then moving it a bit, no issues. Not sure if it's because I waited a bit or because there wasn't enough fluid to come out. Temps were in mid-high 40's both days.
Is this just an issue of not letting it heat up long enough? Or is there something else that might be wrong (e.g. a clogged filter or vent somewhere)? Thanks in advance!
