If you are losing boost juice I would want to make sure all of the hoses are good and tight in the fittings. The source of a leak is much more likely to be coming from a hose than the booster itself.
If the leak is coming from the booster I would change out the whole unit rather than do it piece meal.
Brake Systems, Inc. in Portland, OR are a good source for booster parts. They are also a good source for asking questions about any problems you might be having.
Brake Systems Inc. - Remanufacturing
