Old 12-02-2020, 04:13 PM   #1
Engine: 5.9L 24V-L6 Cummins
Rated Cap: 37'
What is a "7.3 Diesel engine"?
Hey folks!
What is a 7.3 Diesel engine? I've tried researching it, and it seems they are on the really old buses (and thats where I'm seeing it in listings also), perhaps the pre-DT466 engine? Any good? Should it be paired with any particular transmission?
Thanks everyone!
Sevier is offline   Reply With Quote
Old 12-02-2020, 04:16 PM   #2
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by Sevier View Post
Hey folks!
Thanks everyone!
7.3 is a Navistar engine, used in its medium-duty offerings and supplied to Ford for some of their light-duty / medium-duty truck applications. It came in two versions - an IDI and the PowerStroke (not to be confused with its successor - the 6.0 PowerJoke). Some later Navistar versions of this were dubbed the T444 / T444E, as it is 444 CID.
Good engine if maintained well, better with a turbo, but not a powerhouse. As for transmission, depends on the application. I prefer and recommend manuals myself, but they are getting harder to find these days.
Most Ford minibuses will have the AOD or AOD-E, possibly the 4R75W, depending on year model. Larger buses, I would try for the MT643 or 2000. You almost never see these with the better transmissions, but they are out there. The AT545 is the base offering, not a terrible transmission but it does have its limitations. Most will do fine for low-speed without a lot of highway and mountains, but have been known to fail. If either are in your plans, I would suggest the MT643 or 2000 Allison. It's possible a few may have been built with MD3060s, but I've not seen one.
Old 12-02-2020, 04:32 PM   #3
Rated Cap: 37'
Ah! It IS a V8 Turbo! 1987 Thomas - those old ones are so pretty.
Thankyou Cheese_Wagon!
Old 12-02-2020, 04:32 PM   #4
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Sounds like a good buy for the right price if it's not rusty and mechanically sound. Is it a conventional or a flatnose? If flatnose, is it a Saf-T-Liner?
Old 12-05-2020, 11:26 AM   #5
Rated Cap: 37'
It is a conventional, International Thomas, 225K miles, $8,500. Also found an 1988 International Thomas, 209K miles, $9,500 but it doesnt have a Turbo engine. They have high ceilings though, and no rust. Still trying ton confirm the length w the seller, and looking for a mechanic to inspect them.
Old 12-05-2020, 02:38 PM   #6
Chassis: IH
The 6.9 was the predecessor to the 7.3 and was built through 1987 - the 7.3 replaced it (as well as the IH 9.0L) in 1988 as neither could meet emissions coming into 1988. So be advised that for an '87 year model, it may have the 6.9 (it's also possible the 6.9 was swapped for a 7.3 at some point, since they are largely interchangeable.) The two engines are visually similar so it's easy to mix them up.
Old 12-06-2020, 04:05 PM   #7
Rated Cap: 37'
Oh thats really helpful, I'll make sure its a 7.3 proper!
7.3 diesel engine, engine, old bus, transmission
