08-02-2020, 09:12 PM
Year: 98
7.3 powerstroke cranks but no start
Evening folks,
I have trouble with our E350 power stroke van.. No start.
Have this van for 15 years and installed a tachometer about 5 years ago.
Last trip was running fine, turned it of and would not start again.. waited 4 hours and fired up without a hitch. Then drove fine.
Started first turn last week, today zero, cranks strong. tacho shows 200 RPM.
with ignition key.
CEL lights up for 1/4 second and then goes out
WTS comes on and goes out together with clicking of GPR
Batteries fully charged.
Mechanical pressure gauge shows 70psi fuel pressure at schrader valve
Torque pro shows
HPOP 2300 psi while starting.
No stored ecu codes
Replaced IDM, no difference.
Probed CID signal , shows high low when cranking.
IDM return signal about 3 volt DC and 6 VAC with fluke DVM
With Car gauge pro I ran a KOER test
passed
Ran buzz test.
All injectors buzz.
Measured injector harness
All ohm out to 3 OHM on IDM connector with IDM removed
I did not measure FCDS but I would think that circuit should be good with going thru a buzz test?
No white smoke or unburnt diesel smell
What am I missing, suggestion please
Johan
08-03-2020, 10:06 AM
Is the ECM powering up? Occasionally my ECM decides it doesn't want to turn on. It will crank and cranks but never start.
08-03-2020, 04:29 PM
Year: 98
hi e450,
I have read that if the WTS light comes on for the time it needs to glow that the PCM =(ECU) is running.
This morning it fired without a hitch. have been testing all day with auto enginuity software and scanner. No clue why . only code I got was
P0603 internal control module keep alive memory (KAM) error
P1280 Injector Control pressure sensor circuit low
Took the connector of the ICP sensor and the pressure went to 725 psi.. That is what it should be.. with the connector on it is 500 psi. also good. Couple of resets later it was gone.
The P0603 remains. Trying now to find that wire into the PCM and see if there is a wire problem.
frustrating,, a whole day and it works but I do not know why
08-03-2020, 05:29 PM
Rated Cap: 19
I'm thinking that the KAM error might be suggesting the PCM is losing power for an extended time. Maybe as simple as a loose battery cable.
08-03-2020, 06:03 PM
Year: 98
Hi Roach, yes that is what it is supposed to be, only batteries are tight and always on charge with solar panels..
the other thing is I can delete the KAM error.. Stop the engine, start it again and it is back...
08-03-2020, 07:03 PM
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
sounds to me like the memory chip in the ECM is bad.
08-03-2020, 07:12 PM
Rated Cap: 26 foot
FWIW, I had a "circuit low" code for my fuel pump that kept turning on and off. Even the Cummins dealer and the bus dealer that originally sold the bus to the school system I bought it from didn't know what it meant.
It looks like I have a rebuilt injector module, so I thought it was just a crappy rebuild or something.
In working on my bus, I had to disconnect the in-tank fuel pump at its connector, as well as an "overheat" circuit that was shottily installed by hand that cuts the main power feed wire, runs it up to the motor head and through a thermal switch, and back to the factory connector. I put it all back together, and never had a code since.
So I would guess that "circuit low" means a poor or corroded connection.
08-03-2020, 09:34 PM
Year: 98
I will open up the PCM and see if the KAM memory voltage actually arrives on the board.. If so yes or no then that becomes easy..
I doubt if the KAM error causes no start condition....
If that was caused by a faulty ICP then a whole new can of worms opens up. Faulty ICP or damaged wiring. Maybe I need to splice into the wiring just before the PCM so that I can check the most important sensor voltages at the pcm and also check the most important out put signals to the IPR and IDM.
08-03-2020, 11:14 PM
Rated Cap: 26 foot
If you want to read these sensor values, be sure to use a meter that is designed to work with a running automotive ECU. They have xtra-high resistance internally, so as not to alter the value the computer is reading. My little old Craftsman and my new Klein (from HD - thanks Doktari!) meters are NOT made for that. They would say "safe for automotive use" or something similar. My old boss from 15 years ago was a stickler for that. They are fine for checking other automotive electrical systems, just not sensors.
Good luck to YOU! (and me )
08-03-2020, 11:17 PM
Rated Cap: 26 foot
And do your darndest to backprobe the connector at the ECM or sensor before you start hacking into the harness! You probably know that, and maybe about the type of meter, but for others who read this and are learning...
Aloha!
Edit: use a sewing needle to backprobe if nessesary
08-04-2020, 08:37 AM
a faulty ICP circuit or sensor is "solved" by unplugging it and the engine should always start.. of course that assumes the computer sees an "open" on one or the other leads which is where the 725 default value comes from.
ive seen a no start where a CPS still provided enough signal to generate a Tach reading but not consistent or clean enough to let the computer fire the injectors.. it needs to see the reference point in the signal so it knows the real position of the cam.. if that reference pulse doesnt match up with where it thinks it should be then it wont fire the injectors ..
you'll see a 0 injector pulse width on the scanner (I dont know on the 3 box if you can see the actual pulse width. the IH shows it )
08-04-2020, 02:07 PM
Year: 98
Hi Chris,
Yeah I don't know. The CPS feeds the PCM.. the PCM makes the tach signal..This is all digital, so it would be bizarre that the PCM would send the signal to the tach and not be able to use the signal for the IDM.. a discrepancy something I would think a self respecting software / hardware developer at ford would have set of the CEL light.
In my case i built a IDM breakout box with LED for the FCDS signal , Feedback signal and CID signal . If those signal are there and there is more then 500 psi according the IPS then is there anything else electronic that prevents this thing from starting?
Johan
08-04-2020, 02:16 PM
Year: 98
Power stroke idm injector breakout box
Breakout box with injector switches.
I used the connector from a broken idm box and it counterpart that I cut out of a F series diesel truck..the box I had left over from the time my company made ultrasonic pre amplifiers.. The switches came out of junk equipment.
Johan
08-08-2020, 09:34 PM
Year: 1967
Chassis: Dodge S500
Engine: Dodge 318
Crankshaft Position Sensor. Ever replaced it? What year? 611,000 on my 7.3 I can tell you about everything that will ever fail and kinda when...
11-05-2020, 07:14 PM
Coachwork: Thomas (ShortBus)
Chassis: E450
Engine: 7.3 powerstroke turbo diesel
Rated Cap: 15 person
Please !!! Help your self ;)
11-05-2020, 07:15 PM
Chassis: E450
Would be lovely to hear what happened with this IDM story !
11-06-2020, 12:04 PM
Year: 98
Thanks unplugged... Cps was replaced a by ford under a recall...long time ago.
This intermittant problem started after sitting for a couple of years.
I replaced the idm module but no change.
Do not like to randomly throwing parts at it because with an intermittant problem it only would show results after a couple of weeks..
I made the injector breakout box to get better diagnostic tools.
It is to bad that not more of really in-depth knowledge is available about the cps signal versus rpm counter versus idm sync versus injector pulses. Can a poor cps still give an rpm response and no signals to the idm?
So sofar the problem is not positively resolved.
12-18-2020, 04:29 PM
Year: 98
Since my other bus is still under repair I am driving our 4*4 van more.
So the above random crank but no start has happened twice. Both time the engine started fine and ran for a while then shutoff for 10 minutes and no start.
The first time it refired after several on ,off crank cycles. Luck for me
So the second time i drove to sam's club to get dogfood and engine still warm but crank fast and no start..
The sequence: with engine still warmish..
Turn key..glowplug for 1/2 second..crank..rpm needle moves..oil pressure light goes out...oil pressure needle moves to normal......but no start.
Opened the hood.. tapped and wiggled on idm and pcm relay. No change..wiggled pcm connector ..no change..wiggled idm connector no change.
After 10 6 second cranks I measured the voltages across the pcm fuse and idm fuse... All good...crank and no start..
Then for in frustration I pulled the KAM
Fuse.. immediate start.
Now since this is all random it could mean nothing or something.
Can there be anything set in the KAM memory that prevent the engine from starting?
Any 7.3 powerstroke computer gurus here that have insight in the KAM secrets.
Left the fuse out and vehicle drives the same.
Any takers?
Thank you,
j
Johan
12-19-2020, 03:41 AM
Year: 1967
Chassis: Dodge S500
Engine: Dodge 318
Joe Cam position sensor for sure, especially if it’s been more than a few years since it was done. It’s a cheap parts and super easy to replace. It’s a small external sensor looking for a magnetic bump in the cam. The engine doesn’t know where it is all it will not let the injectors fire. As I recall.l a 10mm socket and done
12-19-2020, 08:22 AM
supposedly the VPM houses the KAM (I think thats where it physically is).. if the ECM cant see the VPM it fgoes into failsafe default mode.. the engine runs on factory programmed defaults for its parameters.. at least thats how navistar does it.. im guessing in those 3 box systems fords and navistar were real similar.. so perhaps the VPM is going bad and sneds off-the-wall data to the ECM whewreas when you pull the KAM fuse the VPM likely is completely offline? so the ECM runs with defaults..
