A hammer, a plastic one (even dead blow) preferred but metal okay with caution.
Attempt to start using the ignition key
IF NO START:
Check for voltage to the starter solenoid and battery to starter cable
IF NO VOLTAGE AT EITHER T/S FAILED CIRCUIT
IF VOLTAGE PRESENT AT BOTH:
Rap the starter housing with the hammer.
Attempt to start.
IF ENGINE STARTS: Remove starter and have rebuilt or replace it it is failing
IF ENGINE DOESN'T START: Continue with additional T/S steps
