Brokedown, I had wondered if I’d need an adapter plate to mount the MT-643 to my 6.6L? Today, I had a chance to pull off the floorboard panel covering above the bellhousing on mine and found the answer I’ve been searching for. Since my 6.6L/AT-545 has a SAE #3 bellhousing, and the MT-643 I found has a SAE #2 being larger in diameter, I figured there had to be an adapter plate somewhere. Answer: the adapter plate is already mounted on my engine to attach the AT-545. I just have to remove the adapter plate to install the MT-643. Problem solved. And thanks for offering to pass on my question. If in fact I do come up with any questions about the 643, I will message you. Thanks again...
