Old 04-09-2020, 02:55 PM   #81
roach711's Avatar
Rated Cap: 19
Originally Posted by mc11237 View Post
Any insights on the rear diff drain and change process?
I believe mine is a Dana 80 dually. Here's a link to the fluid change process:
https://www.dieselhub.com/maintenanc...-80-fluid.html
Basically you pull the differential cover and clean out the old oil then reseal the cover with RTV sealant (there is no gasket). Using a quart pump refill the differential up to the fill port with 75-140 full synthetic (4.2 quarts).
You can see the fill plug in the picture. There is no drain plug.
The Roach Motel
Old 09-10-2020, 10:46 AM   #82
Chassis: Ford E450
Does anyone know what this is on the back of the fuel tank? 2003 E450 7.3L Thomasbuilt.. I am hoping it is an extra fuel pickup that I can tap into for heater, but suspect it might just be a fuel tank vent, hoping someone on here knows.
2planker is offline   Reply With Quote
Old 10-20-2020, 03:44 PM   #83
Okay, officially confused here.... New to skoolie. Net and this thread is my go to for my 7.3l I have an 03 7.3L power stroke and everything on here is saying red elc no problem but my bus has a sticker on the coolant reservoir saying not to do that, am I missing something or do I need to get regular coolant and add the sca?
Edit: I just finished replacing the oil cooler and had to flush the oil and coolant so now im trying to get it on road and running.
Semag4400 is offline   Reply With Quote
Old 10-20-2020, 05:30 PM   #84
roach711's Avatar
Rated Cap: 19
Possibly an older engine has been installed?
From what I've read, the red elc coolant is fine in '00 and up.
The Roach Motel
Old 10-20-2020, 05:34 PM   #85
Let me snag a photo in a few minutes but it's a cutaway E-450 bus I just bought from school bus company. None of the paper work I have says it's ever had the engine swapped. the sticker is from the factory unless they grabbed the coolant res from another type of bus? Anyway I can tell if the engine isn't original?
Old 10-20-2020, 05:44 PM   #86
Old 10-28-2020, 08:32 PM   #87
Update: did the ELC drove it from NJ down to GA with no coolant related issues. Its going to get flushed regardless after removing the heater and fixing/finding the coolant leak near the engine.
Old 10-29-2020, 06:44 PM   #88
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
My bus has a 1st generation T444E, and I have NO warning stickers about coolant, so don't depend on that. I also have a coolant tank that sits about 6 inches higher than my radiator (it's actually up over my alternator), and it doesn't look like yours.
That said, I've been running the old-school green antifreeze in there, and have had no problems.
Hex is offline   Reply With Quote
Old 10-29-2020, 06:57 PM   #89
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Look for marks on the bolt / nut heads for the transmission bellhousing bolts, or signs that the bolts/nuts or engine block are cleaner than the transmission. Also, other bolts and nuts securing other hardware to the engine would show signs of removal and reinstallation.
You can also find the engine's serial # and check it against the chassis manufacturer's records of what engine serial # it came with. All bets are off if it was simply rebuilt, as the serial # would remain the same.
But I hear tales of people using ELC in applications that didn't call for it, as well as using non-ELC in applications that did, without issue. As long as the system is flushed completely, for some applications, it may not be a problem. I have heard of some going to non-ELC due to issues with the non-ELC though.
Old 12-28-2020, 10:12 PM   #90
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Engine: International T444
Rated Cap: 16?
I run cheap traditional green coolant and drain the radiator every 20k.
ISAF2009 is offline   Reply With Quote
Old 01-08-2023, 11:06 AM   #91
Retired Roughneck's Avatar
Year: 2005
Chassis: ford E350
Engine: 6.0 power stroke Diesel Navistar EFI
Rated Cap: wife & 2 corgis
thanks for the initial post!
looked like a old one but still being looked at.
great info even though i have a 6.0
i just learned a lot!
i love this forum!
life is short, travel, camp & enjoy!
Retired Roughneck is offline   Reply With Quote
