Originally Posted by Jolly Roger bus 223
your bus is a chevy express van cutaway.
dont know if you have the 2500 or the 3500 express but either way the 6.0 is the 6.0
also look into replacing the coil packs while you are doing the plugs.
Hey, thanks a million for the response! That said, I should have mentioned that I don't have a cutaway. This is full-sized (36 passengers) bluebird. I'm pretty sure the Express has EFI with electronic ignition. This appears to be carburated with dist cap & rotor so no coil packs. I was hoping maybe an old Silverado or similar had the same parts.
But alas, I think I found what I need. Rockauto has a "Bus" category. Their results look more in line with what I'm seeing under the hood. I think I'll try that.
Thanks again! Much appreciated
Tim
