11-15-2021, 12:27 PM
98 b7, 366 gas engine, 37 ft
I just got done taking the seats all out. I was curious about the weight of it but can't seem to find it anywhere. However on my search, I found out the 366 can only pull 16k lbs (correct me if I'm wrong). My next question is, since most 37ft skoolies I see are around 20k+ when finished, does this mean my dreams with this bus are dead in the water? I went with gas because it would be easy for me to work on, and the 366 engine has parts everywhere... But if it's only able to pull 16k, I'm pretty SOL, right???
Also, I've read that most 37ft busses weight like 20k+ witg seats etc... how can this engine even pull this then? When I drive it doesn't seem to lag or anything, she pulls along just great.
Thanks for all the advice in advance! I appreciate it!
11-15-2021, 12:37 PM
It might be best if you first weighed the bus on a truck scale. That way you will know your starting point. Weigh it with a full tank of fuel.
11-15-2021, 12:42 PM
That's what I plan on doing. I'm just afraid it might break down and then I'll have to tow it back.
But if it does weigh like 15klbs, or more empty. What does that mean for me?
11-15-2021, 01:07 PM
Chassis: Crown Supercoach
Engine: Detroit 6-71TA, 10 sp.
Rated Cap: 90 (40')
Get it weighed as you intend, then compare that to the GVWR listed on the VIN tag to find out the maximum weight you can put into it.
If it drives well now, you'll probably be fine. Don't expect to get anywhere fast, though. Your bus was designed to carry 70-ish children, which is pretty heavy. As long as you're somewhat thoughtful about materials weight, it'll work out ok. If you live in the mountains, want to drive 70 at all times, and want a water bed and marble columns in your conversion, then start looking for another bus
Edit: also use the search function to find others with similar engines. Most seem to be happy enough. My first bus was a bit pokey, but its gas engine got us around just fine (can't remember exact bus details - it's been a while).
11-15-2021, 02:09 PM
Chassis: All American RE 40 FEET
Engine: Cummins 8.3
I used to work for an outfit that had 3 C-70 Chevy air brake 2 axle dump trucks with the 366 engines and used to load out at 35000 pounds regularly and they worked. Wasn't fast but they did it. They could burn through the fuel though. The all had velocity governors under the carburetors to keep you from over revving them. Didn't work going down hill.
Why can't I get Ivermectin for my horses?
11-15-2021, 02:13 PM
You're amazing! I didn't even know the gvwr info was on that plate! It says 28,000 so I'm more at ease now. I plan on keeping it light anyways just because of the MPG I'll get, no washer/dryer, no oven.
It's going to just be a family vacation machine for my wife, dogs, and I so I won't be doing cross country tours with it. More like driving to a state and chilling for a bit.
I'm definitely going to grab a diesel shortie for solo trips when I'm done with this build though.
11-15-2021, 09:15 PM
Engine: 345 international V-8
Pull 16,000 lbs? as in 16,000 lbs of trailer? It should do it, I have had up to 17,000 lbs of trailer behind mine, grossed at 35,000 bus and trailer.
11-16-2021, 05:53 AM
Please take the time to take a pic of your bus so we can all see it. It is not only an investment, its a livelihood.
11-25-2021, 07:14 PM
Coachwork: Our hot little grubbies...
Chassis: Ford CF8000 ExpeditionVehicle
Engine: Cummins 505ci mechanical
Rated Cap: Five Heelers
Early-1990s, one of our full-time live-aboard conversions was a 30' semi-trailer.
Our toter was a 1974 Chevrolet cab-over, 108wb (yup, air-ride seats mandatory).
366ci through an Allison 643.
For most of a decade, we ran Oregon-to-Baja and back a couple times a year ('bi-annually') ('trans-nationally').
Out into the deserts of Idaho, Oregon, Nevada, Arizona ('out').
Beaches along the Oregon coast.
Putzing along in the slow-lane at around 50mph tugging the trailer, we rarely got better than about 5mpg.
Without the trailer -- occasionally enjoying second-gear chirps -- showed about 11mpg at that same 50mph.
Just north of the Oregon border on Interstate Five is a long incline associated with the Ashland volcano ('ash land').
That grade is humbling.
We had eight (eight) minute miles ('strolling').
An aside:
The military surplus auction at McClellan AFB never furnished our trailer title.
Accordingly, we never licensed it.
Never plated it.
Apparently, odd-n-deranged can be too bizarre for state troopers and LawEnforcementOfficials to register on their 'investigation' scale...
