Old 01-13-2022, 09:11 AM   #1
Year: 2012
Engine: 4500 Duramax
Rated Cap: 15 + driver
Diesel Cold Starts
2012 Chevy G4500 Duramax with 195k miles. Iíve had Ďer almost two years, did the interior conversion myself. Iíve always had trouble with cold starts, even at 45ish degrees. I turn key to illuminate the glow coil but the coil only stays lit for about 2-4 seconds and then when I fully turn key, I get one single crank and then it stops. If I half-turn the key multiple times to get coil lit several times (8-10 times) and then try start, it will turn over and start. Battery tests show batteries are fine. Put new batteries just to test it and in the morning, same problem. Itís been sitting at mechanics for a week now while they keep scratching their heads. Thoughts?? Thanks!
Gigirolls is offline   Reply With Quote
Old 01-13-2022, 03:23 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
glow plug contoller/timer?
if you dont have one and have access to power have a block heater added.
the glow plugs should stay on longer.
so what is controlling the time on the glow plugs
Old 01-13-2022, 06:03 PM   #3
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
It sounds like a delay-off relay of some sort. Some of them are adjustable through pin switches. I have on for my heated mirrors.
Rwnielsen is offline   Reply With Quote
cold starts, single crank then stops
