Old 08-18-2020, 10:23 AM   #1
Chassis: GMC B7 T042
Engine: GM 454 7.4L Gas
Rated Cap: 66pas
Power Steering - 2000 GM B7 - 454 engine
disclaimer - I'm fairly inexperienced with mechanical repairs but trying to learn.
I have a bad leak in my power steering hose/fitting from the reservoir to the pump which i am trying to replace. It is the blue hose in the pictures which has a swivel elbow joint at either end - the leak is coming from the lower swivel joint where there is a black plastic sleeve. It is indicated as part #1 on the GM parts diagram
I am not too sure where to start with fixing this - I have not even been able to dissasemble the hose (which appears to be all 1 piece with the 2x elbows). Loosening the hex head (on part 22 on diagram) where it meets the pump doesnt help - it is still fixed. Does is come apart with a clip fitting at the swivel? The swivel elbows seem quite unneccesary and actually allow the hose to rub on the chassis causing wear. I am open to replacing with something fixed.
Hoping someone can help with suggesting how i should move forward with this - how to dissasemble or where to get a replacement part - people have suggested going to a hydraulic hose & fitting shop and just getting something custom made up?
GM parts diagram link: https://www.wholesalegmpartsonline.c...ct=2704627#001
the.brum.bus is offline   Reply With Quote
Old 08-18-2020, 11:18 AM   #2
Chassis: TC RE
Engine: 8.3 Cummins MD3060
I would cut the hose where needed to remove the 2 swivel ends and take it all in to a hose making place and get something made the way you want it. It's been a long time since I have had a hose made, but I was surprised how much cheaper it was that I expected.
JackE is offline   Reply With Quote
Old 08-25-2020, 02:19 PM   #3
Not to derail concerns about your power steering hose joint, but as an even greener newb, would you mind telling me how you figured out the hose was leaking? I recently bought a 2000 Chevy Express short bus and upon driving it home noticed that the steering is alarmingly unresponsive. From ignorance, I'm wondering if it might be a "simple" fix such as yours.
alsquared is offline   Reply With Quote
Old 08-25-2020, 02:30 PM   #4
Rated Cap: 66pas
Yep a custom hose sounds like the way to go... Just need to work out how to disassemble this without breaking anything! I've had a mechanically minded friend (currently swapping a Cummins 5.9 into a Bronco camper) look at it and he gave up on taking it apart
Old 08-25-2020, 02:34 PM   #5
Rated Cap: 66pas
Check for drips on the ground after parked for a while. Monitor the power steering fluid levels in the reservoir to see if it's low or dropping. If leaking follow all the lines coming from the reservoir and connected in the system with a paper towel to find where the fluid is leaking from
Old 08-25-2020, 02:50 PM   #6
But is the steering experience I describe consistent with a loss of power steering fluid and not some more disastrous mechanical failure? I ask just because it's not physically hard to steer, just "laggy" so to speak?
(And thank you again so much.)
Old 08-25-2020, 03:34 PM   #7
Rated Cap: 66pas
Can't help you there... I'm not the most knowledgeable when it comes to mechanics!
Old 08-25-2020, 03:39 PM   #8
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
how are the brakes?
look up chevy hydro boost system troubleshooting and start there.
Old 08-25-2020, 04:01 PM   #9
Year: 86
Chassis: Ford B700
Engine: 8.2
BRUM.BUS.
what year model is your bus?
where is the line leaking at?
it looks like a fairly simple replacement to me but i have years of mechanics experience and just spent the weekend doing the toughest one i have ever done in 27 years. but anyway.
depends on where its leaking really decides the fix.
the elbow (22) at the pump definetly looks pressed but the end of the hose at the fluid resorvoir on the firewall looks more like a form of a compression style unscreweable nut.
never mind i was looking at the diagram and not your pictures.
both end of the hose are/were held on by hose clamps.
take a pair of channellock/water pump pliers and try to twist the hose loose at the connection. if it doesnt budge then take a razor knife and cut the hose length wise over the connection to free it up.
if it is leaking close to a connection then you might be able to cut it there and shorten it up with out having to buy a new hose which could help with its rubbing.
if the threads are leaking at the threads of the elbow at the pump it looks like you still have to pull the hose there to be able to uncrew the elbow.
some of those threaded elbows used a teflon seal ring over the threads to seal them.
but year model will give us more info. about what you have.
good luck
