rotor hub conversion help needed
I have a motor home that has a single axle p30 chassis with independent front suspension. I need to swap the frame out because of rot. I found a great p30 but it is a duel rear wheel and a straight axle front. Because of that, the wheels on the new frame are bud rims and the wheels on mine are regular. Is there a hub that would fit the straight axle but allow me to use the regular rims? like a 4-inch rotor and hub assembly instead of an 8 inch? Both are 8 lug. thanks mike
