Old 01-03-2018, 02:25 PM   #441
oricha1984's Avatar
Engine: gasser probably
not idea engine, but nice body
maybe i jump on this
oricha1984 is offline   Reply With Quote
Old 01-03-2018, 04:25 PM   #442
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Thanks for your experience on your Honda.
My sons CRV was the same and me being the cheap redneck I am I drilled a 3/4" hole in the plate and hand hammered and punched the old one out and new one in. The old school method once access was provided.
If you ever have a rear end/tire,shock, alignment or trailing arm problem then let me know cause I just went through that also and fixed all for 200$ instead of the Honda 4000$.
Good luck
Can't say that the van would work for me? You gotta pick what works for you?
Old 01-03-2018, 05:15 PM   #443
oricha1984's Avatar
Good luck
Glad it helped. For the Honda fit, it seemed like that wasn't an option based on my research.
I need either a big van or a 4 window bus.
Specially now that I have another member to the family [emoji4]
Sent from my Life One X using Tapatalk
Old 01-03-2018, 05:40 PM   #444
Year: 86
Chassis: Ford B700
Engine: 8.2
The mechanics said it wasn't an option?
It took a little time to find a spot but it is there.
To do it yourself you have to keep in mind that there is always a different option?
I researched your fit before I did my sons CRV the body shape is the only difference?
Remember that when if you need to go junkyard hunting?
Need help holler.
Old 01-14-2018, 03:07 PM   #445
oricha1984's Avatar
What is a good computer thingy to read codes?
My local mechanic will probably charge me $50 min. I rather spend some more and do it myself.
Help a novice mechanic out guys !
Old 01-14-2018, 03:37 PM   #446
I bought this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It works with a free Android app.
So far, no complaints.
Old 01-14-2018, 04:49 PM   #447
If your vehicle has a OBD port you can go to just about any auto parts chain and they will read it for free and tell what the codes are. I would quit using any repair shop that charged to read engine codes.
Old 01-14-2018, 05:05 PM   #448
Raul, this will get your codes flashing usually by putting a jumper in these spaces.
Then count the flashes on your eng check light. Codes are then googled if you have no chart.
$49.00 Canadian please, lol (cash only)
Old 01-14-2018, 05:18 PM   #449
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I am very happy with Bosch 1350 scanner.
Name:	Screen Shot 2018-01-14 at 5.11.10 PM.png
Old 01-14-2018, 05:20 PM   #450
Personal engine code readers have become quite popular in the last year. Many on the market for under $20. Get the code and then the internet will tell you the fix.
Old 01-14-2018, 11:52 PM   #451
oricha1984's Avatar
Well, I have the drivewise from Allstate and got an email about the code. The world has become so advanced...
Seems like an oxygen sensor.
Probably not really something to worry about, but I might attempt to fix it myself.
As always there is the potential that I'll make the problem worst, lol.
Old 02-15-2018, 12:15 PM   #452
oricha1984's Avatar
My new bus ???
422 Auction Services - Mathies & Sons, Inc.
hope this one comes out better
Old 02-16-2018, 03:39 PM   #453
oricha1984's Avatar
hehehe,
should i take that thing for $2,500.
looks good on paper but, far from florida
Old 02-16-2018, 04:54 PM   #454
Robin97396's Avatar
It says it's closed at $2200. Anybody take it?
Robin
Nobody's Business
Old 02-22-2018, 06:30 PM   #455
oricha1984's Avatar
Shorties anyone ?
Old 05-06-2018, 01:52 PM   #456
oricha1984's Avatar
finally decided on what bus to buy !!!!
I wonder how those tires will do here in florida
Old 05-07-2018, 06:24 PM   #457
oricha1984's Avatar
cuban engineering
turn old truck into boat.
Old 05-09-2018, 05:30 PM   #458
oricha1984's Avatar
frame problems ?
https://www.rbauction.com/2005-THOMA...788.1487033847
is that hole on the frame stock ?
Old 05-09-2018, 08:17 PM   #459
IDK, probably. Most frames have holes for various things that may or may not come fitted to the actual vehicle.
Doesn't look detrimental to me. Looks pretty clean under there to me.
Old 05-09-2018, 08:27 PM   #460
oricha1984's Avatar
Yeah, I felt the same way. I just thought it was weird that they took pictures of that specific area.
Anyhow, it sold for 5k + fees.
