That light is activated by a sensor on the fuel filter. The sensor is no more then a float that raises when water is at the bottom of the filter. There is a plastic petcock on the bottom of the filter that you can drain. However, I'd recommend replacing the filter entirely, as you've likely never done it.
The filter is located inside the frame rail beneath the driver's seat.
