Old 10-17-2016, 08:04 PM   #1
warewolff's Avatar
97-03 International T444E Service Manual PDF
Took me a long time to track this down and compile it ... download the PDF for free HERE, or pay $120USD on eBay. It is complete minus a few blank pages to cut down on the file size.
ENJOY.
warewolff is offline   Reply With Quote
Old 10-17-2016, 09:18 PM   #2
I have that and also have the full Oncommand which is about 5 gigs of stuff...
i think my t444E diagnostics is interactive if run in windows.. I know the oncommand is.. does your T444E have 9 sections mosrt of them dated from 2004?
and of course internztional gives away the servicemaxx J1708 now which is what we need for the T444E / DT466E
Old 10-17-2016, 11:30 PM   #3
Rated Cap: 65 pax
ENJOY.
Mines a 2003... THANK YOU! My son-in-law the mechanic may need this one day
Sandi
WanderWoman is offline   Reply With Quote
Old 10-18-2016, 06:58 AM   #4
remember to downgrade your IE or run it in compatibility mode for ie8 or ie9 and set the security low enough to allow activeX to run... that whole setup (if its the same one I have) is browser based...
we need a palce to compile service information for the busses..
Old 10-18-2016, 08:50 AM   #5
Chassis: B3800 Short bus
Here is the T444e Diagnostic Manual as well: https://www.dropbox.com/s/y1vt3i3ude...mized.pdf?dl=0
It has some really useful flowcharts. I've used them a couple times to diagnose electrical issues.
Old 10-18-2016, 08:53 AM   #6
is that the one which goes through the Computer as well as the mechanics?
I have 2 now one that is more the mechanics, and one which tests and shows proper values for all of the Electronics as well.
Old 10-18-2016, 08:57 AM   #7
It is largely electrical diagnostics, including the computer modules. If I'm not mistaken, it also has mechanical diagnostic flow charts, but it doesn't walk through repair procedures. That's when the service manual steps up to the plate.
Old 10-18-2016, 09:11 AM   #8
perfect it sounds like the same set I have then.. thats exsctly how the 2 volumes I have are.. one does the diagnotsics and the other manual shows you how to actual remove and reinstall the parts...
this is a great time to be compiling this information as more and more members are buying HEUI busses...
one thing to add is that the full set of info I have (I think its the same that the OP posted).. also covers some diagnostics and info on the cummins engines when they were used on an international Chassis...
a lot of the T-444E diagnostics for the electronic sensors also applies to the DT-466E, as the 466E also utilized the HEUI system.. while the mechanics are totallty different, the concepts of the fuel and oil systems are vewry similar..
the cummins are not HEUI engines, they use some electronic controls but most of the ones we will be dealing with in the forums here will be mechanical Injection pumps.
Old 12-15-2016, 07:07 PM   #9
Engine: t444e
I owe you a beer
ChiliChzPoopTart is offline   Reply With Quote
Old 01-16-2017, 03:09 PM   #10
Coachwork: blue bird
Engine: international 3800 t444e 7.3L
thank you so much. ive been needing those 2 pdfs so bad.
welcomehome is offline   Reply With Quote
Old 01-22-2017, 09:07 AM   #11
meteoricide's Avatar
Coachwork: IC
Chassis: IC3S530
Rated Cap: 41
What WelcomeHome said ... times 8! Thank you!
No matter where you go .... there you are!
meteoricide is offline   Reply With Quote
Old 05-26-2017, 07:13 PM   #12
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
By chance does anyone have the electrical diagrams? I have a gremlin that sets off my dash alarm everytime I pull the headlight switch. Drives me crazy.
The brake pressure sensor specifically is the one going off. I think probably it's the tan wires off my headlite switch maybe melted into the brake pressure sensor wires....pls jesus be easy...
rock649 is offline   Reply With Quote
Old 05-26-2017, 07:54 PM   #13
I have the full on command set for 2014 but it's like 6 gigs
Christopher
Old 05-29-2017, 12:40 PM   #14
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
Well, I'm gonna take the positive wires off the starter one at a time till the short stops and then I'm gonna chase it I guess.
Old 05-31-2017, 10:12 AM   #15
Chassis: Amtran
Download issues
Having trouble here at work, I'll try at home and hope for better luck. Less Security at home.
MotorMike is offline   Reply With Quote
Old 06-14-2017, 02:44 PM   #16
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
Check this out!!
International ServiceMaxx Software is Now Free - Diesel Laptops Blog
Old 06-14-2017, 06:42 PM   #17
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
https://www.navistarservicesoftware....p/servicemaxx/
If the top one doesn't work try this one
Old 09-05-2017, 03:51 PM   #18
cschuck3's Avatar
Engine: DT360 Diesel
Can I get the updated link to the owners manual ( 97-03 International Manual ) ?? I have a Thomson International 3800 DT360 Engine
cschuck3 is offline   Reply With Quote
Old 09-07-2017, 10:28 PM   #19
Year: 97
Coachwork: Moi
Engine: 444e...7.3L
You will want a detroit engine manual. International is the chassis maker...and they do have their own engine line...but detroit is a different engine company altogether. Actually I think that Thomas is a coach maker company. So your frame is international, cabin is thomas and your engine is detroit. You may luck out...but you might have better luck in the detroit engine/drivetrain forum.
Old 09-08-2017, 09:32 AM   #20
Probably not.....
DT-360 is manufactured by International along with it's larger siblings, DT-466 and DT-530.
