Originally Posted by 8Linermemphis
Anyone have wire harness diagram that will show ignition. Switch wire diagram??? Lost key and nobody at local parts stores have the exact one that came in it. So gonna have to use a 3 post ignition switch if that will work ? Thanks for any help
Many international ign switches are keyed alike at the factory.
Try this because i know it works.
Old square head, single cut gm/chevy keys. Get your hand on a few, insert into lock and jiggle and rake the key. Many many times it works!
As a retired repossesor i have about 30 gm square head keys that i used to repo international trucks!
Din’t cut or modify your wiring !
You tube- raking gm trucks ignition and see it in action .
Also, you can call the intl dealer parts dept.
Give them the vin and ask for a line set on the vin.
On that line set it will have the key code for the lock. A locksmith can cut a new key with the code.
