Originally Posted by Smittybilt
Were there ever any busses produced in the early 2k's with a standard transmission? The experience I personally have with the DT466 was back then, I was working for a line clearance tree company and my tree truck was set up with the DT466 and a 6 speed manual transmission. I loved this set up, it worked really well around town as well as out on the highway. I have not spent too much time looking for a bus specifically with a standard transmission, but in the searching I have done I have not seen one. Just curious if they were ever offered. Or, on the other hand, how much of an ordeal would it be to convert?
Thanks to anyone who might shed a little light on the situation.
Smitty
Standard advice is to get the bus with the powertrain you want as converting later will probably cost more than the bus is worth. This was certainly the case for me.
I replaced the AT545 in my 93 ford/Cummins with a 6 speed. I had to scrounge up a clutch pedal assembly and linkages, SAE#2 clutch housing/engine adapter, flywheel, clutch, different starter, had the driveshaft modified, etc. Changing the stuff out was not complicated but certainly time consuming.
I had no luck ordering parts (not even the transmission) everyone wants to know the part # which of course you don't have! The only upside is that you can inspect/rebuild as you go.
Changing the gear ratio is pretty straight forward and with a little asking around you can figure out what that would cost on a bus you are interested in. You have experience with the 466 so you have an idea of what gear ratios would be reasonable for the size of bus you choose and you can get a lot of feedback here on the forum.
