Originally Posted by Jay Are
I don't know anything about pulling the codes. Could you comment on how much I should expect to fork out to have them pulled?
Thanks, safe travels!!
LOL. That was a good one!
Pulling codes means retrieving coded data from the computer. It will tell you if the computer sees a problem. It will issue a 3 digit code which corresponds to a particular issue.
Theres two ways to pull codes.
1) code reader
2) dash retrieval.
The first one will require you to have a laptop and a nexiq compatible reader.
The second way is easy and free. I do not know the correct procedure so hopefully someone will chime in, but basically you push a button and count the light, how many times it blinks. That will get you the code.
