Originally Posted by Clouse House
So if I had to guess since I have On/Off and Accel/Deccel buttons
On/Off probably does the same function
Maybe "Deccel" is "Set" leaving "Accel" to be it's normal self.
Your setup sounds similar to mine. I have two rocker switches on my dash aboard my CE200. One is marked “Throttle On/Off” and the other is marked “Accel/Decel” (I’ll find out what the other switch says and amend this)
Ideally the switches are marked for the throttle, on mine, and they can be set for cruise, which simply involves switching on the “On/Off switch and once you’re at the desired speed, you press the “Decel” one down and it should hold the speed. I don’t use the “Accel” part of the switch cause you can set the speed simply by using the throttle pedal, and that method also works for high idle when the bus is stationary.
