Originally Posted by Goingmerry
Thanks for all the help, I am now almost certain it is the sensor for the back lift door that got disconnected some how during demolition and then mistaken for a speaker wire when we stripped those. Should be easy enough to fix once I get a replacement wire I’ll just have to figure out which one of the plugs to plug it into above the front door.
And yes I hope someone else takes this as a warning on how easy it is to make stupid mistakes. Unfortunately I’m extra dumb because I did read up on lots of this prior to doing anything electrical and still pooped it. We were checking lights and following lines to be careful as we went and just from inexperience and perhaps a bit too much eagerness made this stupid mistake.
I can't resist jumping in here with my experiences with a VanHool Coach in commercial service I still drive for a friends' Charter Company. As most Coaches today are being MANDATED to have wheel chair access and equipment built in, all it does is makes simply using and conducting normal operations nearly impossible when a stupid sensor SOMEWHERE goes on the fritz.
This particular VanHool has a habit of not sensing the chair mechanism stowed and the door closed properly. The result was that it's impossible to release the parking brake (the same as this yellow air valve button), and put the coach into gear. It's a BITCH to get the damn thing figured out to isolate what sensor is causing it, all with passengers loaded and waiting to depart, and the customer getting pissed at the unmovable coach.
Needless to say I've worked up, a very well earned through very BAD experiences, a truly deep down LOATHING and active HATRED for all the add on, so called "SAFETY" SH*T they load up the newer buses of all kinds today. All it ever does is make them LESS SAFE and very dangerously unreliable in performing their most basic functions of being able to move passengers (and cargo), down the road in a controllable, simple Safe and Predictable manner.
This is the main reason I have no desire to ever learn to drive the new generation of Setra's, VanHool's or even Prevost's which have gone over to the dark side. I much prefer any older MCI but unfortunately here in KommiFornia they're doing all they can to drive any coach older than 2010 off the road by not letting them be registered by DMV. I've had friends in business be forced to unload perfectly great revenue generating MCI's merely because the Dictators in charge here deem he can't use it to make money anymore. These coaches are built for 20-30 years of commercial service and it's a true Crime to force a business to get rid of them while still in the prime years of their service life with many productive years left in them to run profitably. Truly a Crime.
This just doesn't sound like the USA I'm used to living in, where a soulless government can in effect steal a business owners means of production through unconstitutional Diktats. (Oh No! Covid! shut everything Down!!!)......Please don't get me started.
This poster has his hands full and will need to carefully find out about the wiring and sensors and interlocks and see they are ALL properly dealt with so he won't compromise the safe operation of his bus. It's literally worth his life and his family's life to find a properly trained and maybe even certified mechanic or shop to deal with this and restore it to a safe and reliable condition. By all means get rid of the wheelchair related crap if you can safely do it, but seek help and do it right. Unless you need the chair lift there should be no need to put up with the flakiness of random sensors that will override parking brakes and transmission functions like I have to with that VanHool.
Beware of the other common little "safety" add-on that forces the driver to get out of his seat and go to the back and push a button when you stop and shut the bus off. If you don't the interior lights start flashing and the horn starts honking and you can't stop it without re-starting the bus, or pushing the button within a certain time limit... This needs to be gone too.
I'm sure there's more lovely little land-mine gotcha's being added every day to the list of "Safety" systems that only make them less and less likely to ever be able to drive down the road at all.
Just my observations and 2 cents and worth exactly what you paid for it. But I've earned my cynicism the hard way and I'm not going to apologize for it. I'll just avoid at all costs the newer vehicles. I'm happier that way. Cheers.
