Old 05-05-2020, 06:48 PM   #1
Allison 3000 problems
I have a 2002 international 3800 t444 with Allison 3000
I’ve owned it for about 8 months. Basically setting in my yard. I go out and start it every few weeks. I tired to move it the other day and the engine just revs up and it tries to move But won’t, I assume the transmission is just slipping. Please tell me there’s a simple fix. 🤞🏼🤞🏼🤞🏼Thx
Jwlt500r is offline   Reply With Quote
Old 05-05-2020, 06:51 PM   #2
dmattarn's Avatar
Engine: DT466E Allison 3000
Rated Cap: 84 Kids/56 Adults
Have you checked the fluid level?
"Once you get it, you got it."
dmattarn is offline   Reply With Quote
Old 05-05-2020, 07:22 PM   #3
Chassis: Wayne Lifeguard
Engine: 7.3L IDI
Rated Cap: 23,600 lb
Have you released the brakes?
AzironaZack is offline   Reply With Quote
Old 05-06-2020, 03:22 AM   #4
Has the air pressure built up to operating pressure?
Old 05-06-2020, 06:13 AM   #5
Johnny Mullet's Avatar
Engine: T444E 7.3L
Start bus and let air pressure build to 100+ psi. Release the parking brake and try again.
Old 05-06-2020, 11:30 AM   #6
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
make sure all your emergency exits and doors are closed. my bus wont move until those conditions are met. it made for an embarrasing few minutes the first time i went to a truck-stop to fill up. the emergency door was latched, but not QUITE enough. after i did a walk around I reclosed the latch and off i went.
stlthe is offline   Reply With Quote
