Forewarning, LONG (unintentionally) to reduce the amounts of questions upfront.
I'm in the midst of addressing all my drivetrain issues/concerns on my 2000 T444E / MT643 combo, RE 33' IC flat nose.
I've addressed the oil and air already. I just added an EGT gauge but haven't tested it because of my tranny.
My electric modulator has become the focus of another thread on here,
https://www.skoolie.net/forums/f37/m...oad-34679.html. I tested the modulator in and out of the tranny per Christopher's (CadillacKid) instructions and no clunk. I'm awaiting a replacement modulator after an amazing offer from Christopher.
Even though I have checked the tranny fluid, my failing sense of smell and knowledge of what burnt fluid smells like failed to tell me my tranny fluid was a milk chocolate color. I'm not sure if this is actually burnt or simply old??
So, now I'm "planning" (replies from this thread may change that) to not only drain and change the spin on, but drop the deep pan and clean it out and change the internal filter.
Per other threads, it appears the MT643 does not have a torque converter drain, so I'm planning on going with Dexron III for about 5k miles to clean out as much of the old fluid and change it out to Transynd.
Besides the transmission not downshifting automatically (see my posts in above listed thread for details), it upshifts and downshifts in light load situations and manually shifts if needed with no backtalk from the tranny. So, I think that my tranny is still solid, but needs attention and as much help as it can to get "going" (key word) down the road.
That brings me to this question, should I add an auxiliary tranny cooler??
I read other threads about the importance of fluid operational temps and I'm like 98% sure my bus has an integrated tranny cooler with the radiator since it's a 2000 and my engine and tranny temps run pretty close to each other.
My tranny usually runs about 190, yet during my last modulator test run, it got up to 200-205 in 50 degree weather, which I understand it still well within normal. But, again, milk chocolate tranny fluid.
The bus has lived its whole life in Seattle with no high heat (schools out when it's "hot" (85-90) up here for a few days a year) and no passes to climb.
Since the MT643 is a wide range four speed, I'm imagining some higher temps when in hotter climates and long up-hill pulls.
If I were to put an auxiliary cooler in, I would not use a fan. I was thinking, if it's available, to use an internal thermostat and bypass set up to assure I don't run too cool (yes, there's such a thing as too cool).
If you made it through to this point, I dub you Knights of the Long Post. As always, your time, knowledge and feedback are greatly appreciated.
