Originally Posted by PB612
This is a good option. The bus you have did have this as an option so at least fabrication will be more limited then something that was not a factory option. It is non computer controlled, and your bus being a 96 is not computer controlled. I would go with a manual trans, there are a number of 6 or 7 speed trans that will fit.
Putting a 6-71 in is not going to be easy. and will need a lot of fabrication. I do have one for my shorty with a 5 speed eaton twin counter shaft trans. This came out of a dump truck. It does weigh a lot more then the original 444, so heavier springs, maybe even heavier axle might be in order. Service on the road will not support this type of build, you are on your own.
Staying with original equipment options lets you get parts and repairs anywhere that can service medium duty trucks.
Just a few thoughts....
