Old 06-29-2020, 08:00 PM   #1
Shortbus PA's Avatar
Chassis: BE 200
Bombproofing an International VT365 V8 Turbo Diesel?
I'm a total newbie who just purchased a 2007 International BE300 Short Bus (6 window) with a VT365 V8 Turbo Diesel engine and an Allison 1000 automatic transmission (158,000 miles on it). I've read threads saying my engine is not reliable unless it's "bombproofed" ... can someone tell me what this bombproofing process entails?
Shortbus PA is offline   Reply With Quote
Old 06-29-2020, 08:15 PM   #2
On a VT365 it’s not as involved as a Ford 6.0, you can look up bulletproof A ford power stroke 6.0. ( IH made the Diesel engines for ford)
On the VT365 oil cooler and EGR cooler with aftermarket units will keep things going. It isn’t tuned so as long as your head gaskets check out good now you don’t need to do head studs.
The VGT turbo could sometimes stick causing low boost / black smoke or turbo lag if it stick open..
Making sure the engine cooling system is in good order.. radiator , fan clutch, temp gauge and proper coolant. You don’t want to overheat your VT365, you can ruin it easy. Might want to get a bluefire J1939 device where you can see the engine data from the computer on a tablet or smart phone screen. You can monitor oil temp and turbo boost which aren’t on the normal dashboard.
The IC BE is a nice little platform .. be mindful of the weight you add to it during conversion and since it has small wheels try not to add lots of weight high up, it will drive squirmy if it’s too heavy..
Christopher
Old 06-29-2020, 08:41 PM   #3
Chassis: BE 200
Thanks, Christopher ... that helps! As for the weight issue, my bus also has the wheelchair lift (it works great!) and I was thinking of keeping it and using it as an outdoor deck and even as a shower. But do you think it's too heavy to keep?
