308k miles on Thomas Vista 3600 Handy with T444e 175HP sending power to a AT545 transmission.
Coming around a downward bend a loud clatter began so I pulled over to inspect things.
So far I THINK I have ruled out the following:
fan clutch
All pulleys. (Sound still present with belt off)
Injectors. (Temp remains the same on all cylinders using laser thermometer)
The turbo has no play and is dry
I BELIEVE the flex plate is okay. I removed the tranny, torque converter and Pulled the flex plate and a visual inspection appears that it is fine. (Nothing close to what a damaged one looks like on line)
I also ordered in a Scangauge D and was throwing no codes before I tore into things.
I have the tranny on jacks about 10" from the motor and can't figure out what the problem is.
I removed the flexplate because the sound was exactly like the one in the video.
Looking for further suggestions.
Thanks,
~Jamie
