I am going to assume it's air brakes then?
I'm with Chris, one tap... if it's that rural I'd prob use a tractor and do the low and slow crawl if I had to
what about a generator and an air compressor, air up the brakes that way? you don't really need the power steering at that low a speed would you? (I dunno)
I was wondering the same thing when I had my transmission swap about if they can run without transmission attached
also funny story is I also damn near swapped flywheels and **** by accident because I thought they were the same, and had to go with the transmissions I was swapping (a member here stopped me from making a very bad choice)
As for your transmission swap options it depends on what motor you have.
I had a 7.3 and if you read the transmission swap threads here an MT643 wasn't happening (the adapter ring) so I went and put in an electronic allison 2000
so a couple notes on your trans work. Well i will edit. I have a bad habit of ignoring the "member info" on the left under our monikers... this is just me, and I looked for the engine in your post
DT466 you can throw in an MT643 pretty easy and it will have lockup in 3-4
1. you can do it yourself easy. Chris did it alone, and I did it alone, and we are not but wee lads...
2. Read Cadillackids "Redbyrd Transformation", in entirety, FIRST! THEN read my thread "Transmission Options" AFTER... it's important to go in that order
Chris breaks down everything about it, how they work and is full of solid info. and also shows you how to R&R a large trans without dying.
My thread shows how followed Chris, but I cheated to get the Allison 2000 installed without touching a computer because I am a straight duffer with numbers and computers. And it also has pics and shows how you can R&R as a wee man without dying.
The one thing I learned was that whether it was an AT545 or a 2000 I now know that I can R&R one in a parking lot in a day with simple hand tools...
Cheers
