10-05-2020, 06:09 PM
#41
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by brokedown
Axle ratio should be on a badge above the windshield.
Not all of them. Actually, I've not seen one yet that the body tag / decal gave that info. I believe there is a tag somewhere on the housing that shows the 'born-with' ratio (irrelevant once re-geared)
10-05-2020, 06:27 PM
#42
Year: 86
Chassis: Ford B700
Engine: 8.2
his original thread is up on the board now cause i revived it and it is rear axle swap ford 4 window shorty.
i offered help for interchange because my son works at a ford dealership as a mechanic and can have them pull specs up.
and thats how i was going about donor vehicles and gearing in rear ends.
in a PM with them they were talking 3.1 or 3.7 rear gear but didnt say towing anything or just want road speed
10-05-2020, 06:35 PM
#43
Year: 86
Chassis: Ford B700
Engine: 8.2
if you know how to clean off the grime without destroying them the tags are there and if older stuff then clean it enough you find the casing stamps. that is the tell all?
sorry on older stuff.
if your tags or missing on rear end transmissiom motor? then research the location and find the casting stamps of what you think you have
10-05-2020, 06:49 PM
#44
those tags are a pain... I had a whole bunch of numbers on the Differential in my Superior.. still no one could find anythin from them.. its pre 1981 so the VIN was non standard.. I finally pulled the 3rd member out and took it to weller truck parts where a bunch of old guys looked at it and had the books out and were searching stuff on the computers.... then one other guy walks up from the back says "Oh thats an RA-39 rockwell out of a International Loadstar.. what do you need done to it?"
10-05-2020, 06:59 PM
#45
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Just goes to show, there are times when books and decoders are useless.
10-22-2020, 06:47 PM
#46
More Power, you are amazing! Thank you for helping out with all those VIN inquiries!
If you get a chance, my son and I would love to get the details on our 2000 Bluebird (International 3800 T444E). We think the transmission is an Allison 2300, but can't find anything to confirm that. The VIN is 1HVBBABN7YH344417.
10-23-2020, 07:52 AM
#47
1HVBBABN7YH344417 Was built with an Allison at-545 4-speed. Includes tc-290 torque converter & trans oil filter. Does not include retarder or pto gear.
10-24-2020, 01:09 PM
#48
Engine: 7.3 International
Hey More Power could you do mine please?
1HVBBABM51H366560
Your awesome btw
10-24-2020, 02:35 PM
#49
Chassis: Vista 3600
Rated Cap: 24000 lbs
Yeah this is the quote of the year
They SHOULD BE
sadly they never seem to be
10-28-2020, 05:11 PM
#50
1HVBBABM51H366560
Your awesome btw
1HVBBABM51H366560 Is exactly the same as the last one (it’s a common configuration for international buses). Allison at-545 4-speed includes tc-290 torque converter and trans, without retarder or pto gear.
10-29-2020, 10:40 AM
#51
Thank you More Power!!
02-16-2021, 09:36 PM
#52
More Power could you decode my vin? I’m getting a lot of weird returns using any of the free decoders online. I was told my bus has a DT466 with an Allison trans. Most of the decoders are saying it has a Cummins engine which I doubt but I’m really curious which trans is in it. I haven’t driven it home yet but I have to cross over a mountain and want to know if it’s going to be a struggle. Thank you.
VIN: 4DRGSCLN8PA056852
02-16-2021, 10:31 PM
#53
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
A picture of the engine would be far more helpful in figuring this out. As you have seen, the decoders aren't necessarily accurate. Navistar engines are typically painted a blue / blue-green color, Cummins engines are often painted tan, black or in some cases red. I've seen a few that were painted green on gensets and such. Anyway, the point is that the only way to positively identify your engine is to see it, which in this case means uploading a photo, which you will be able to do after 5 posts. Alternately, a Navistar dealer may be able to tell you from the VIN.
01-11-2022, 09:10 AM
#54
More Power
I am trying to buy a bus, and the owner is hundreds of miles away, and can't send me pics of the tranny, or motor. The vin number is not adding up regardless of which source I use. Maybe your guy will have better luck? I know it's an old thread, hopefully you'll get this.
1HVBBNEM9MH337988
01-11-2022, 09:14 AM
#55
Call Dealer
Originally Posted by MyIQisLow
More Power
1HVBBNEM9MH337988
You could also call the international dealer with your VIN and they will give a lot more info than just which transmission it has.
01-11-2022, 12:00 PM
#56
Chassis: Amtran
More Power
1HVBBNEM9MH337988
If you are going to tow or do highway driving, make sure you get a good drivetrain or you will regret building it out.
01-11-2022, 01:12 PM
#57
That's why I am trying to figure this out. The Dt, or the Cta are the only motors, and the mt643, or md3060 are the only transmission I am considering (unless I could find a manual, that would be ideal, but almost non existent.)We are definitely going to tow lots, while boondocking, in as deep of snow as we can find. That's what we do for fun. Thanks for the replies so far.
01-11-2022, 05:20 PM
#58
Engine: 345 international V-8
There is a tag on the side of the trans that will include model number.
01-14-2022, 10:16 AM
#59
1HVBBNEM9MH337988 Was built with an Allison AT-545 trans.
01-14-2022, 02:29 PM
#60
tranny swap thats what ive done on 2 of my busses
