CE200 (t444e) diesel supply issues
I have a CE200 bus with the T444e engine. I started it to get ready for a trip and it ran for a bit then died and won't start.
The fuel tank is full but the fuel filter/bowl is empty. I have noticed a small diesel leak in the valley when I turn it off.
I primed the bowl but it still didn't start. I checked the bowl and it was empty again. I left the top off the bowl and cranked and nothing happened. No diesel pumped in. Seems like the fuel pump has failed.
I plan on replacing the o rings in the bowl but it seems like I also have a fuel pump issue.
The plan for now is rebuild the fuel bowl and replace the mechanical fuel pump. Is there a lift pump on these in line or in the tank that I should also look into? Seems like the tank is really far for just the one pump.
Thanks!
