Originally Posted by Sporto
Does anyone have any other suggestions about clearing the Engine Oil Change warning lights (little yellow wrench) and odometer statement?
2013 IC AE with Maxxforce 7.
Thanks everyone.
Rich
RESETTING CHANGE ENGINE OIL SERVICE INTERVAL
MESSAGE
As per
MaxxForce ® 7
Engine Operation and Maintenance Manual
Reset the Service Interval Message (change engine oil) per the
following procedure:
1. If not already done, set the parking brake.
2. Turn ignition switch to ON.
3. Turn CRUISE ON.
4. Turn CRUISE OFF.
5. Turn CRUISE ON.
6. Very rapidly push the resume switch four times and then hold
down on the fifth time for 4 seconds.
7. The operation from the time the CRUISE is turned ON for the
second time to the fifth activation of the resume switch must
take place within 6 seconds. If you fail to reset the message,
repeat the process.
8. The Change Engine Oil Service Interval message should
clear and reset for the next service interval.
Those c/c buttons if i am not mistaken are routed thru the body control module. If those buttons were operating " lights stop traffic" (stop lights?) then either they did a hard wire re-route or reprogrammed the BCM to perform that function.
If I am correct al all, then dealer only or find someone with the DLB software.
