Originally Posted by Free Bird
If you can do 60 (without lugging) at under 2000 rpm you're golden!
When I did my AT545 to Allison 2000 swap I was running originally at 2400 to get 57mph with the AT545. Now I did learn that fresher fluid I prob would have gotten better performance, so lets say I topped out max rev and speed at 60mph.
I have a 4.78 rear end and I keep the cruise set at 64mph and I am running 2050 RPM on the T444E now that I have the Allison 2000 in our 7 window Vista
My top speed is a bit over 75 but I stopped accelerating about there and was at 2300..so not much more, and I would be pushing the motor and I treat her better than that.
I recently pulled our 18ft Stingray behind the bus and on moderate grades on the highway (hills, not mountains) I didn't lose any speed and held 64 and 62 on the worst hill.
I agree that a 64mph top is ideal, mostly as when everyone else is doing 70+ you can set cruise, keep a good clip, and a wide open highway in front of you.
As far as the two speed rear ends I did some research into this, as a manual swap was next on the list if my 2000 swap wasn't going to happen. I found that most of the split rear ends were mostly dump trucks or the like and offered a choice of short, and then shorter.
Stupid question, but one would have to have a manual to run a split rear end? Could it be done on an automatic Transmission by shifting to Neutral for the split?
I've run them in manuals, been a long time ago. Never heard of one breaking like that... those poor kids, but I also wonder what the specifics were...I don't think this is that common a thing, or is it?
But, in the end if I could run a split rear, with a 4.78 what would be the ideal number to match to that in a split rear? I know it doesn't exist, and its highly unlikely it could be done with an auto. But curious what would pair well with a 4.78
or what combo would be ideal in a "perfect split rear"
