Crank no start T444E 54,000 miles 10,000 hours, with servicemaxx
Greeting skoolie people,
God is good but my bus is not /
Can somebody please help me out
I have a crank no; start does anybody know the minimum voltage of the battery? /
I read the codes from the diagnostic button, then cleared the memory.
CODES:
111
144
124
113
323
313
626
525
I read the codes again but nothing came back /
I decided to post this message for a better attack
The motor is a 7.3 (T444E) /
Year of manufacture 1996 + 3/
It used to start and run fine, then ran rough suddenly.
I am not sure where to think /
The text below is from USB link.
SERVICEMAXX PARAMETERS KOEO
Signals
ID Name Value Units
66010 ECM Serial Number 0154221
70002 Vehicle Retarder Control Mode Disable
71001
Glow Plug / Inlet Air Heater Control
Mode Glow Plug
72001 Exhaust Back Pressure Control Mode Disable
72011 EVRT Warm-up Enable
73001 Engine Crank Inhibit Mode Disable
74001 Engine Idle Shutdown Timer Mode Disable
74010 Engine Idle Shutdown Time 5 min
74021
Engine Idle Shutdown Maximum Intake
Air Temperature 111 F
74031
Engine Idle Shutdown Minimum Intake
Air Temperature 61 F
ID Name Value Units
75001 Auxiliary Engine Speed Control - Mode In Cab Operation Only
75011
Maximum Vehicle Speed 20 mph
75021
Auxiliary Engine Speed Control - In Cab
Mode Stationary Variable
75031
Operator Interface Enable
75041
Remote Pedal Enable Disable
75051
Auxiliary Engine Speed Control - Preset
Engine Speed 1 (Set) 1,000 RPM
75061
Engine Speed 2 (Resume) 1,200 RPM
Parameters
Page 2 of 3
ID Name Value Units
75071
Auxiliary Engine Speed Control - Ramp
Rate 250 RPM/s
75081
Maximum Engine Speed 2,600 RPM
76001 Cruise Control Mode Enable
76030
Cruise Control Vehicle Speed Low Limit
35 mph
76041
Cruise Control Vehicle Speed High
Limit 62 mph
77000
Engine Warning & Protection System
Mode
3-Way Warning (RPM,
ECT, EOP, ECL)
77011 Engine Coolant Warning Temperature 228 F
77021 Engine Coolant Critical Temperature 235 F
77031
Engine Oil Pressure Engine RPM
Boundary 1 700 RPM
77041
Boundary 2 1,400 RPM
77051
Boundary 3 2,000 RPM
77061
Engine Oil Warning Pressure for Region
1 5 psi
77071
2 10 psi
77081
3 20 psi
77091
Engine Oil Critical Pressure for Region 1
2 psi
77101
Engine Oil Critical Pressure for Region 2
5 psi
77111
Engine Oil Critical Pressure for Region 3
12 psi
79001 Road Speed Limiting Control Mode Disable
79011 Engine Speed Limit with VSS Fault 2,458 RPM
79021
Max Vehicle Speed with Road Speed
Limiting On 80 mph
80001 Two Speed Axle Enable Disable
80011 Tire Revs Per Mile 514.0
Revolution
miles
80020 Rear Axle Ratio Low 4.10
80030 Rear Axle Ratio High 4.10
80041 Transmission Top Gear Ratio 1.00
80051 Low Axle Ratio Pulses Per Mile Count 33,718
80061 High Axle Ratio Pulses Per Mile Count 33,718
80071 Transmission Tailshaft Gear Teeth 16
82001 Transmission Type Allison AT/MT
82011 Engine Family Rating Code 2131
82020 Low Idle Engine Speed 700 RPM
82030 High Idle Engine Speed 2,700 RPM
82041 Rated Engine Speed 2,400 RPM
82051 Rated Power 210 hp
ID Name Value Units
82071 Regulation Type
83001 Total Fuel Used 10,312 gal
83011 Total Engine Hours 5,872.7 hr
83021 Total Miles 54,250.6 miles
84001 Engine Speed Fault 1 Engine Hours 0.0 hr
84011 Engine Speed Fault 2 Engine Hours 0.0 hr
84021
Engine Oil Pressure Fault 1 Engine
Hours 0.0 hr
84031
Engine Oil Pressure Fault 2 Engine
Hours 0.0 hr
84041
Engine Coolant Temperature Fault 1
Engine Hours 3,474.0 hr
84051
Engine Coolant Temperature Fault 2
Engine Hours 3,476.5 hr
84061
Engine Coolant Level Fault 1 Engine
Hours 5,832.0 hr
84071
Engine Coolant Level Fault 2 Engine
Hours 3,406.7 hr
84081 Engine Speed Fault 1 Total Miles 0.0 miles
84091 Engine Speed Fault 2 Total Miles 0.0 miles
84101 Engine Oil Pressure Fault 1 Total Miles 0.0 miles
84111 Engine Oil Pressure Fault 2 Total Miles 0.0 miles
84121
Total Miles 37,080.1 miles
84131
Total Miles 37,129.9 miles
84141
Engine Coolant Level Fault 1 Total Mile
54,187.9 miles
84151
Engine Coolant Level Fault 2 Total Mile
36,399.5 miles
85001 Vehicle Identification Number HTMGABKXXA020488
88001 Engine Serial Number 7.4HM2U0800476
89005 Vehicle Speed Select Mode
Enable Hardwired OSS
feature
90001 Engine Fan Control Mode Disable
90021
Fan On Temperature for Engine Cooling
Control 212 F
90031
Fan Off Temperature for Engine Cooling
Control 208 F
91001 Radiator Shutter Enable Disable
91011 Radiator Shutter Open Temperature 203 F
91021 Radiator Shutter Closed Temperature 176 F
92001 Coolant Tank Selection
Float Sensor (Plastic
Tank)
93011
Driveline Status for Hydraulic Pressure
Governor Operation Split Shaft
94001 Cold Ambient Protection Enable Enable
95001 Service Interval Mode Disable
95011 Fuel Used Service Interval 1,000 gal
95021 Engine Hour Service Interval 350 hr
Parameters
Page 3 of 3
ID Name Value Units
95031 Vehicle Distance Service Interval 10,000 miles
95041 Fuel Used Starting Value 0 gal
95051 Engine Hour Starting Value 0.0 hr
95061 Vehicle Distance Starting Value 0.0 miles
95071 Service Soon Percent 100 %
95081 Change Oil Lamp Always On No
95091 Change Oil Lamp Activation Time 30 s
95101 Service Interval Reset Request No
95111 CDPF Fuel Used Service Interval gal
95121 CDPF Engine Hour Service Interval hr
95131 CDPF Vehicle Distance Service Interval miles
ID Name Value Units
95141 CDPF Fuel Used Starting Value gal
95151 CDPF Engine Hour Starting Value hr
95161 CDPF Vehicle Distance Starting Value miles
95171 CDPF Reset Request
96001 Allison Transmission Shift Schedule
97001 Traction Control Enable
99021
EGRP closed position reference reset
request
99041 Fuel Quantity Governor Mode Enable
THANKS
