Old 05-26-2023, 05:15 PM   #1
Dash replacement CE300
I have a CE 300 dt466 2008 model with 2006 engine.
The dash coolant temp gauge does not work. I just drove it home for the first time about an hour trip. Using bluefire I monitored the oil and coolant temps and they both stayed around 196 +- 3 degrees.
I would like to replace the dash cluster and have found several cheap used ones with the same p/n number, but they came from buses with VT365 engines. Does anyone know if this matters?
It seems like the dashes of this era are just "display" units without smarts, but I really don't know. Does anyone have insight to this?
t-chuck is offline   Reply With Quote
