Old 05-17-2024, 07:02 PM   #1
Engine: DT-466
DT-466 / AT-545, just broke down
Iím traveling through Wyoming, and it seems like weíve been going uphill all day. Suddenly I had a brief loss of power (for less than a second), and then it was okay again. That happened again a few minutes later. Then, I started really losing power, got white smoke out of the exhaust, heard some loud clanking or banging sound when pressing the gas pedal down, and I lost all power.
Now Iím sitting on the side of the road some huge distance from any nearby town, and donít know what the problem is, how to fix it, or if I can limp to a town or at least to a better spot to pull off.
Any ideas?
Beeb is offline   Reply With Quote
Old 05-17-2024, 07:05 PM   #2
Engine: DT-466e, AT-545
This is also me. I’m just commenting from my other account where I can actually get notifications of responses.
Beeb2 is offline   Reply With Quote
Old 05-17-2024, 07:33 PM   #3
ewo1's Avatar
White smoke???
Did you lose all your coolant ?
Also check engine oil dipstick.
Is the oil dark brown or does it look like a creamy milkshake?
These two simple checks is the beginning of your troubleshooting process and will help others in helping you.
Old 05-17-2024, 07:45 PM   #4
Engine oil is drastically lower than it was, and there are signs of a leak under the engine that were not there prior to the trip today. That being said, the oil isnít completely gone, but it is very low. Dark, maybe slightly milky, but I honestly donít know. I am trying to attach a photo, but it wonít upload from my phone. I guess my service isnít good.
I honestly donít know where to check the coolant.
I just tried starting it up again and it sounded really bad and then died. So I guess Iím calling a tow either way.
Old 05-17-2024, 08:57 PM   #5
ewo1's Avatar
Please forgive this next comment as I am not trying to offend but you really shouldn't drive the bus cross country if you don't know how to check the coolant!
That is a recipe for trouble.
If the engine is stone cold then remove the radiator cap and check for coolant. DO NOT open it if the engine is hot as you can/will get burned....badly!
Oil level is a concern but on a DT engine if your low on oil it will most likely just turn off by itself as the injectors need high pressure oil in order to operate correctly.
It is really important to know the color of your oil. If it is more white than brown then you got serious issues going on.
I attach these two pics so you can have an idea of what your oil should NOT look like.
Is your oil all dark or creamy/milky white/gray?
Any white/gray is a sign of bad news.
The noise you say it makes.. does it sound like banging or scraping/screeching?
Also, the reason why it starts and then dies, let's hope that it is nothing but low on oil but we need to know the color of the oil first.
Old 05-17-2024, 09:40 PM   #6
No offense taken. You're absolutely right.
I took the cap off, and don't see anything inside. I don't know what coolant to even put in it though, or how much. I'm very mechanically uninformed, especially about my bus.
I just compared your photos to my oil. No, my oil doesn't look like that. It is very dark, almost black.
Old 05-17-2024, 09:44 PM   #7
Videos!
Here is me checking my coolant: https://youtube.com/shorts/9AZ23fx-WAs
Here is me catching the tail-end of the sound the engine was making when I tried to start it shortly after first breaking down: https://youtube.com/shorts/sM6APUjYxxw
Here is me trying to start the bus again about a half hour ago: https://youtube.com/shorts/UiHUQwqnOuY
Old 05-17-2024, 10:08 PM   #8
One more video:
A better view of inside the coolant cap: https://youtube.com/shorts/qLwI6_33lqo?feature=share
Old 05-17-2024, 11:50 PM   #9
fo4imtippin's Avatar
Chassis: TC2000 28ft
I would recommend not keeping trying to turn it over. I'm not great with engine sounds. You have something hitting something else in your engine. This could be a spun rod bearing causing the connecting rod to break and beat around your cylinder which would cause a loss of compression (white smoke) and then cause low oil pressure which would stop your injectors from firing. It's possible it's something else as well. I would certainly call for a tow before trying a roadside recovery..
Old 05-18-2024, 12:58 AM   #10
nikitis's Avatar
Rated Cap: 29
Yeah sounds like a rod knocking. Something is knocking that shouldn't at least.
Old 05-18-2024, 08:29 AM   #11
Yeah, prior to your comments, I tried one more time and the knocking sound was much more pronounced, so I stopped.
How bad of a position am I in? Is this going to be a full engine replacement? And if so, what's that roughly going to cost me?
Old 05-18-2024, 08:59 AM   #12
nikitis's Avatar
Rated Cap: 29
Need to have a mechanic look it over but assuming it needs a new engine there are options but its gonna cost. Potentially you could find and buy for like $4k, but doesn't include installation. A typical job like this can start at $12k with engine purchase up to $20k max.
If its something g simple or not in too bad of shape and can be remanufactured it is gonna be a little cheaper possibly but not much. I'm only going by what people here have reported the costs to be. Varies by mechanic and location.
If you are lucky, and its something even simpler to fix you may only be in for a couple grand. It needs to get looked at to figure your options.
Old 05-18-2024, 10:11 AM   #13
my DT360 sounded exactly like that when it lost prime and fuel ends up unburned and fires off at the wrong time..
it sounds to me more like an injector stuck open dumping fuel in a cylnder...cylinder is trying to fire extrenely early thus the sound..
the sound is definitely with the engine rhythm and not a once per rev of the crank sound... so likely not a spun bearing... that'll have a faster cadence..
*OR*
you lost a head gasket and that sound is hydrolock - water in the cylinder..
problem 2 it lost its oil and the HPOP went dry and shut down the engine.. possibly because it was diluted by excess fuel and leaked out?..
problem 3? fueling issue?
lots of things going on here... getting a DT466 hot.. even 230 degrees hot can prove fatal for the engine...
wyoming.. im assuming on either 90 or 84 / 80 and climbing up to 9000 feet.. thats pure hell on a bus unless you drop down a gear and take it slow...
im just tossing ideas with the small amoiunt of info here...
Old 05-18-2024, 11:47 AM   #14
Actually, I was on Route 20/Route 26. I went that route specifically to avoid big hills, but it ended up being one big long hill for 200 miles.
I have a tow truck on the way now. They’ll tow me all the way back to Casper, and then we’ll see what happens next. The bus is my baby, but I don’t know if I can swing $20k…
Old 05-18-2024, 12:13 PM   #15
ewo1's Avatar
well at least your oil is black, that is one good sign.
After listening to your videos I think that cadilackid suggestions of a head gasket might be where your heading. the coolant had to go somewhere!
Low oil level, you mentioned it had a leak. How often do you check your oil ? when was the last time you checked while on your trip?
In any event, your headed to a mechanic shop as anything you do now going forward will involve opening up the engine and inspecting!
Old 05-18-2024, 12:14 PM   #16
I check the oil before driving each day. I know there wasn’t a leak prior to starting out yesterday, but clearly something developed along the drive.
Old 05-18-2024, 02:12 PM   #17
turf's Avatar
Sorry to hear about your troubles... hopefully the solutions arent too much.
im not close, but kind of, if you need something, a homebase or shipping addy or something... maybe i can help. im in northern Colorado, about 5 hours from casper.
i'd say you probably have a good selection of qualified diesel mechanics around there. stay away from the big shops and it'll be reasonable.
good luck!
Turfmobile Build Thread
Old 05-19-2024, 10:18 AM   #18
good luck!
Thanks! We made it to a shop in Casper after a long day. Theyíll start diagnosis today, so we should know whatís happening soon. Hoping for the best.
Old 05-19-2024, 10:28 AM   #19
As I mentioned, thatís not the road I was on, but just to make sure Iím doing it rightÖ
When I start going uphill, I drop down into 3, 2, or 1 depending on how steep it is and how much it sounds like itís struggling. The RPM goes up really high and the engine sounds like itís working harder, and my speed drops really low depending on the grade of the hill. The high RPM and engine noise is mostly what Iím unsure of. It sure sounds like itís straining more.
Am I doing something wrong?
Iíve never seen the temp gauge get up to 210, but it does sit around probably 200.
Old 05-19-2024, 11:21 AM   #20
Engine: T444E, Allison 2000
Sounds like fuel knock.
Also sounds like timing is out.....failed sensor?
New oil leak concerning.
Very curious.
Word of advise. If your not mechanically inclined. Spend the money on having the bus inspected least once a year and before road trips. A $150 rad hose replacement can save thousands.
Omnibot2000 is offline   Reply With Quote
broke down, dt466, help me, loss of power, white smoke
