Old 04-07-2021, 10:09 AM   #1
ewo1's Avatar
DT466/570 - 2004 service manual
I just found the holy grail!
2004 DT466 / 570 service manual
432 pages
It is free, not $250 bucks... and this one is in English!
Here is the link, download and save before it is gone!
http://docs.diesel-data.com/Heavy%20...(EGES2651).pdf
I also found the complete service manual for 2000-2003 engines too!
364 pages!
International Doc EGES-210-1
http://docs.diesel-data.com/Heavy%20...(EGES2101).pdf
Old 04-07-2021, 10:16 AM   #2
ewo1's Avatar
DT466/570 2004+ emission sensor wiring
Here is the International doc EGED285
Basically a map of all the sensor wiring for 2004+emiision engines
Old 04-07-2021, 10:24 AM   #3
ewo1's Avatar
DT466 530 Supplemental Diagnostics (EGES215C)
Here is another good one...
DT466 / 530 Supplemental Diagnostics
EGES215C
http://docs.diesel-data.com/Heavy%20...(EGES215C).pdf
Old 04-07-2021, 10:37 AM   #4
ewo1's Avatar
99-06 bus body wiring diagrams
Here is another holy grail !!!
RE bus bodies !!!
99-06 Bus body electrical circuit diagrams for RE200 & RE300 bus body.
International service doc # S08335 dated 02/2008
http://docs.diesel-data.com/Heavy%20...20(S08335).pdf
sorry for all the links but these files are too large to upload!
Old 04-07-2021, 10:41 AM   #5
ewo1's Avatar
2007 + International RE bus body wiring
This one is for busses that are 2007 and newer, RE body type
http://docs.diesel-data.com/Heavy%20...20(S08334).pdf
Old 04-07-2021, 10:43 AM   #6
ewo1's Avatar
2010+ International RE bus wiring
And this one is for International RE busses manufactured after August, 2010.
http://docs.diesel-data.com/Heavy%20...20(S08345).pdf
Old 04-07-2021, 10:46 AM   #7
ewo1's Avatar
2004+ Instrument Sevice Manual (S08314)
01 - (2004) Instrument Sevice Manual (S08314)
File Type: pdf 01 - (2004) Instrument Sevice Manual (S08314).pdf (938.3 KB, 84 views)
Old 04-07-2021, 10:50 AM   #8
ewo1's Avatar
2001 - 2012 Internation RE Radiator & Cooling System (S12043)
Here is another for RE cooling systems
international Doc # S12043
For RE busses with side radiators.
File Type: pdf 01 - (2012) Radiator & Cooling System (S12043).pdf (1.21 MB, 43 views)
Old 04-07-2021, 10:55 AM   #9
ewo1's Avatar
2001-2004 International FE bus wiring manual
01 - FE300 (2004) Instrument Service Manual (S08313)
Another fine service manual covering Int. FE busses, 2001-2004
File Type: pdf 01 - FE300 (2004) Instrument Service Manual (S08313).pdf (859.1 KB, 51 views)
Old 04-07-2021, 10:57 AM   #10
ewo1's Avatar
2007+ Int. FE wiring diagrams manual
(June 2007) Wiring Diagrams (S08331)
File Type: pdf (June 2007) Wiring Diagrams (S08331).pdf (1.22 MB, 35 views)
Old 04-07-2021, 11:24 AM   #11
Jeez dude, you're good. 1995 DT466 anywhere?
Old 04-07-2021, 12:40 PM   #12
ewo1's Avatar
Viscous Fan drives service manual
i'll be hunting that down and post it once I find it...
But in the meantime...
Here is another....
International doc # S12002y, formerly CTS-5055T
Dated 08/07/2000
Old 04-07-2021, 12:49 PM   #13
ewo1's Avatar
IC bus built after 01/2000 Electrical diagrams
Antoher treasure trove for "IC" bus models, lots of body wiring diagrams.
SERVICE MANUAL
International Doc # S08286
197 pages
http://docs.diesel-data.com/Heavy%20...20(S08286).pdf
Old 04-07-2021, 12:56 PM   #14
ewo1's Avatar
Disc Brakes Service Manual
2 manuals here, one pre 2002 and the other is post 2002.
DiamondLife (Bosch Pin Slide) (After June 2002) Disc Brakes Service Manual (S04047)
Old 04-20-2021, 10:06 AM   #15
Chassis: RE300
Engine: DT466e High Torque 258 max HP
Thanks for sharing, great stuff!
ACBeymer is offline   Reply With Quote
Old 04-20-2021, 10:26 AM   #16
Year: 1994
Engine: DT408 6.7L L6
Shoot me your email in a pm and I'll send it to you. I have it on my computer.
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 04-20-2021, 10:55 AM   #17
ewo1's Avatar
Glad I can help!
Old 04-21-2021, 11:25 AM   #18
Chassis: TC/2000
Engine: 5.9 Cummins 12-valve
Rated Cap: 1
Think I broke it. Got this pdf but when I went back, the web site "not found"
BamaBus is offline   Reply With Quote
Old 04-21-2021, 11:32 AM   #19
ewo1's Avatar
The site is a bit funny, wasn't working for two days but yesterday and this morning it was...now this afternoon...404 error message.
I would try again later, this site has TONS of good information/files!
I'm downgloading everything I need...and don't need cause I don't know what I'll need tomorrow!
Oh wow...5 minutes later, site back up!
Old 05-21-2021, 01:13 PM   #20
Chassis: Genesis
Rated Cap: 30,000
Greatly appreciated
Can't thank you enough for all the manuals you sent for my 1996 DT466. Keep up the great work!
BuddyTheMutt is offline   Reply With Quote
