DT466- Updated I6 EVRT/VGT Diagnostics - tech tip
Title: Updated I6 EVRT/VGT Diagnostics Check Sheet and Turbocharger Repair Procedures for engines that exhibit DTC 353 / 354
Applies To: 2004- 2006 MY EGR DT 466 and 570 with EVRT/VGT Turbos with ESN 2,000,001 - ESN 3,000,000
Customer Complaints:
1. Low Power (Can be intermittent)
2. No Acceleration
3. Excessive Smoke.
4. Engine Light on , DTC 353 and /or DTC354 Active or Inactive
Possible Diagnostic Codes DTC 353 - Variable Geometry Turbo control over duty cycle. DTC 354 - Variable Geometry Turbo control under duty cycle.
Possible Causes:
The ECM logs DTC 353 and/or DTC 354 codes when the Exhaust Back Pressure
(EBP) is too high or too low for specific engine operating conditions.
ï Turbocharger actuator (SRA) binding or sticking.- Repairable or Replacable
ï Turbocharger linkage binding or sticking. - Repairable or Replacable
ï Pivot Shaft binding in the actuator (SRA) Flange Bushings. - Replacable as Pivot Shaft Flange Kit
ï Intermittent or low voltage/ground to turbo actuator (SRA). - Repairable
ï Incorrect pressure reading from the EBP sensor. - Repairable
ï The turbocharger vanes or other EVRT/VGT components internally binding, sticking or damaged.- May Not Be Repairable , May need the Turbocharger replaced.
ï Plugged/damaged exhaust system or catalyst/muffler. - Repairable
This doc is 6 pages. download it / print it out and save for future reference.
