Old 05-01-2021, 12:08 AM   #1
Chassis: IC RE300
Engine: DT466E (250HP/880TQ) / MD3060
DT466E Stock Boost
Hey crew, my 2002 DT466E 250HP HT is posting 16lbs of boost and I’m feeling like that is a bit low. I’m reading it from a scan gauge that came with the bus and the bus has 135k on the dial.
I have not swapped the boost sensor, but could, jus thought I’d ask. I have not pulled the intake piping off the turbo and checked for wheel play yet, but any other thoughts are appreciated.
halfdime is offline   Reply With Quote
Old 05-01-2021, 12:43 AM   #2
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
That does seem low. I have a 230HP standard torque DT466E with 225,000 miles and I see around 21-24 PSI of boost at high RPM/load...
Are you getting a 'Warn engine' light? Or only low boost?
johnbloem1974 is offline   Reply With Quote
Old 05-01-2021, 07:59 AM   #3
Chassis: IC RE300
No engine warning light, replaced ICP IRP, runs and idles smooth.
Only thoughts are pressure sensor, hose or turbo related. I guess that the wastegate may be opening early or not fully closed?
Old 05-01-2021, 10:31 AM   #4
Rated Cap: 16
Yea, if you haven't replaced the MAP sensor (located on the top of the valve cover, closer to the rear of the engine) do that one too...
I dont have any experience with wastewater as I have a non-wastegated turbo, but it certainly wouldn't hurt to double-check all the hoses...maybe a small leak somewhere that is preventing proper boost?
Hopefully @cadillackid can chime in as he is a smart dude and I bet would have better insights than I! ;)
Old 05-01-2021, 11:32 AM   #5
I thought the HT units ran lower boost as they fuel Heabvy in the lower RPM ranges and ran actually a alightly smaller turbo to achieve this so you dont end up with high amounts of boost on the high end but you get more boost in the low / mid RPM range than the guys with standard torque units..
I domt have the service book with me to troubleshoot boost but of course all the normal stuff.. checking the waste gate (if equipped) , turbo boots ,clamps, etc. . looking for black smoke (low boost often results in black smoke)..
I plugged a tuner into my 444E, punched it, everything flew off my dash and my boost hit 29 PSI
Old 05-01-2021, 03:43 PM   #6
Rated Cap: 16
YES!! That's hilarious!
29PSI? WOW. How high can you go before damage is done?
Was that using the Orion?
Old 05-01-2021, 10:44 PM   #7
Chassis: IC RE300
Cadillackid, would love to know what you find if you have a minute to look. It spools up like any typical turbo diesel. WOT pretty much any where once spooled results in 14-16psi
Old 05-02-2021, 07:55 AM   #8
yes thats the orion.. I didnt have it set at the highest.. I forgot that I had left my EFRC set at 2161 instead of going to the mild power tune of 2141.
I did set an ICP code but was right before my chicago trip so I havent had a chance to see whether my HPOP petered out (needs to be bigger) or if my IPR just didnt react quick enough..
the ford guys frequently make 40 PSI of boost on tuners using the stock turbo..
back to the 466E HT, navistar built these engines to fuel HEAVY in the low end.. essentially I call it a controlled mini-lug .. the fuel curver sends lots of fuel in the low RPM range to gain torque levels.. they use a turbo which tends to spool up quicker in the lower end but doesnt have a ton of high end boost.. getting more air in the cylinders at low RPM allows you to burn more fuel.. its hell on the pistons (thus why they use heavier duty pistons in the HT versions)..
in the turbo world, smaller turbo spools up quicker but wont provide much high end boost. bigger turbo spools slower but needs more RPM to get going and will push higher boost levels at the higher RPMs.. for torque you are operating i nthe lower RPM ranges, thus getting air in the holes quicker is important..
the newer engines went to VGT or Variable geometry turbos which can spool up quick in the low RPM range and then the vanes change to push more boost in the higher RPM range.. the VT365 / 6.0 and I beleive CAT C7 were some of the first to get those.. IH put them in the DT's starting in 04.
Old 05-03-2021, 11:37 PM   #9
Chassis: IC RE300
Thanks Cadillac. I'm familiar with the turbo limitations from old racing days, but transitioning to commercial diesel and fuel strategy is a bit different.
So basically what I am hearing is that I should go with a HX40 and get fuel remapped to maintain flow at higher RPM and get an EGT. Especially if the turbo wheel has shaft play.
Who out there offers a programmer for the ECM?
Old 05-04-2021, 12:46 AM   #10
Year: 2013
Chassis: IC RE
Engine: HT570 / 3500SP
Rated Cap: 4
Good luck.
ABBus is offline   Reply With Quote
Old 05-04-2021, 12:04 PM   #11
Originally Posted by ABBus View Post
Good luck.
im currently in a Beta program for the Orion which is Power-hungry-performance tuner for the 444E / 466E / VT365 engines..
im not sure of his actual release date but it sure seems like a promising product
Old 12-03-2024, 11:22 AM   #12
Chassis: CE300 Conventional (PB105)
Engine: 2009 Maxxforce DT (GDT210S)
Rated Cap: 72 (I think), 13 Window
Necromancy Used
Necromancing an old thread.
What is the 2024 recommended tuner or ODB2 guage for DT466E engines 2003-2009?
AllisonWanderland is offline   Reply With Quote
