Old 06-18-2024, 04:49 PM   #1
Engine: DT466e 215hp Allison 2500
DT466e would not shut off... grinding noise?
Hope someone can help figure out what's up with my bus.
The bus has not been started for 6 weeks, today I put the batteries back in and it started right up as normal. It ran for a few minutes then something in the engine area started making a very loud grinding noise. I ran and turned off the key but it stayed running but the grinding noise stopped ... had to run out and hit the switch in the battery box to shut it down.
Right now if I turn the key to where the gauges should sweep during pre-start it instead turns the starter and fires up the engine. When it started the second time the grinding noise was gone and I shut it off this time by key
Wondering if I should try a new ignition switch first?
Think it may have been the starter trying engage that made the loud noise?
Thanks!
Timeline is offline   Reply With Quote
Old 06-18-2024, 08:43 PM   #2
sportyrick's Avatar
Chassis: F33695
possible ignition switch, that grinding was the starter engaging so something is amiss. If the solenoid were to stick then it could be back-feeding power to everything...so the run on feature. Same thing if the ignition switch were to short out or stick.....everything is running all the time.
Old 06-19-2024, 07:07 AM   #3
stuck starter relay?
the IH computers utilize 2 relays to allow the starter to engage.. a Power relay which powers up everything with the ignition.. and a starter relay..
the power relay must ne engaged for the starter relay to get power.. if the starter relay is physically stuck pulled-in then it will send power to the starter solenoid anytime the Power relay comes on.. when the key is on, the engine can run so if the starter spins it then its going to run..
rick also brings up a good point.. IH ignition switches are kind of a known failure point as well...
Old 06-19-2024, 05:59 PM   #4
First off thank you Rick and C.K.
Bought a new relay and ignition switch today...
I put in the new ignition switch but it did not fix it, the starter turned the engine over on the first click where it should just sweep the gauges...
On the fire wall there is a small plastic relay with a label next to it reading "Start Motor Relay", I replaced it with a new one. The key switch then worked normally and the bus started right up. Thought it may be fixed, but....
In just a half minute or so the very loud grinding noise started again, quickly turned the key and it did shut the engine off, but once again the ignition switch is not working right, it powers the starter on first click....
Wondering what to try now?
THANKS!
Old 06-20-2024, 01:19 PM   #5
Hey it's fixed!
I found the nut holding the ground wires on the starter to be loose, cleaned the connectors and tightened that nut. Seems to be good to go.
The starter and flywheel seem to have survived.... praying.
Thanks Rick and CadillacKid!
Hope someone in the future finds this thread if their dt466e won't shut off by key, starter engages while engine running or gauges fail to sweep engine starts instead because of loose ground connection at the starter .... So I added some keywords for the google spider to crawl.
Old 07-14-2024, 10:02 AM   #6
Well I thought the problem was fixed but it was not. The starter again began to grinding against the flywheel for a moment before I could hit the key off...
Found that all 3 starter bolts were very loose. Pulled the starter out, end gear was heavily damaged. Got the starter rebuilt by a local shop and installed it along with a new neutral safety switch.
This fixed it, seems like the ring gear survived.
Good to go again!
The starter rebuild using USA made parts cost $340.
Old 07-15-2024, 12:52 PM   #7
nikitis's Avatar
Rated Cap: 29
Sounded like to me it's the solenoid on the starter not letting go.
nikitis is online now   Reply With Quote
