Old 05-04-2010, 12:03 PM   #1
frank-id's Avatar
da: dual battery hookup
This should not be a difficult task. First some information is needed. Are the batteries 6 volt or twelve volt? Is the long cable red in color? Is there a short cable with 2 cable ends? Look at the starter closely and look for any voltage information. Look at the alternator for any voltage information. It is difficult to make a long distance decision with out all the information. Are the batteries the same size and amperage? Any other battery cables in the battery area?
Send more information..... Frank
Old 05-13-2010, 01:32 AM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: dual battery hookup
Originally Posted by hetero
Hello
Working on an `88 International bus, took out the batteries to charge and forgot how to rig them up again! Does anyone know the batteries hookup? The only two wires to connect to the bus are black, one a bit longer than the other, which I'm guessing is positive but not quite sure. Attempts to hookup result in flying sparks.
Just hook them up opposite of what you are doing now.
I'm hungry!
You Gotta Let Me Fly
rv sewer hookup bansil Conversion General Discussions 6 09-21-2014 11:05 AM
Dual batteries, or not? timmygyu Short-Bus Conversion Projects 2 02-18-2012 03:16 AM
Dual ACs for the bus bapos Heating, Cooling and Appliances 18 06-08-2011 10:22 PM
Building and wiring an RV electrical power pole hookup. Locutus Conversion General Discussions 2 06-15-2010 07:05 PM
Main Battery - Starting Battery Group 31? 8D? Tone Conversion Tutorials and How-to's 5 04-16-2009 05:02 PM
