You did all the diagnostics you need to. The primer pump leaks fuel and needs repaired.
Everything before the actual lift pump is under vacuum. So the primer pump, filter, water separator, hose, fuel pickup. etc. are all under a vacuum and subject to air intrusion issues. If you have fuel leaking at the hand pump, you more then likely have air leaking too. What happens is that after you shut it off, the air leaks into the hand pump/system, which allows the fuel to return back to the tank. With the line full of air now, there is no fuel to the engine, and it won't start until the air is purged and the fuel system re-primes.
Hand pumps leaking on these are the #1 culprit for hard start/no start after sitting for awhile. With fuel being thicker then air, if you have a fuel leak at the hand pump, it's almost a guarantee that air is leaking into the system at that spot too, and is the cause of your problems.
