Old 04-18-2021, 08:17 AM   #21
Originally Posted by Ironworker85 View Post
I do have the blue nexiq box wat all would I be able to change with the software?
any and every parameter.. the god-mode service max essentially is a source-code mod that applies the Hash on every parameter so the ECM never refuses a program code.
the Horsepower is changed by altering the the EFRC (engine family rating code) the the HP code.. each EFRC and HP is a pair and must match each other.. ie tyou cant just arbitrarily set the HP at 500 and get any gains as it wont match the EFRC..
but say you upgraded your turbo, HPOP and sticks you could run a DT530E program that expects big sticks (not sure how your pistons would fair)..
if you have a Valid subscription to NavKal you can use servicemaxx ,change the VIN and Engine serial number in the ECM and then use NavKal to download calibrations for that combo..
Old 04-18-2021, 08:27 AM   #22
So with the blue nexiq box would I be able to bring the HP to 230?
Ironworker85 is offline   Reply With Quote
Old 04-19-2021, 08:28 AM   #23
Iím jus tryin to find a way to get this ecm up to 230 the local dealer ship wants ya to jump thro hoops and buy a lot of parts to go up a few HP
Old 04-19-2021, 10:38 AM   #24
Go to the UserCP and fill out your profile with your location and bus info. Makes it easier to handle requests.
Old 04-19-2021, 11:22 AM   #25
Will do thanks bud
Old 04-19-2021, 11:28 AM   #26
s2mikon's Avatar
Engine: Cummins 8.3
Just remember that VW ag now owns Navistar and they (VW) have already run afoul of the EPA. They are going to be very gun shy of touching anything that might bite them in the a**. These low hp dt’s don’t have adequate piston oil cooling to run heavy loads of fuel. They are a lot like early 855 Cummins in that regard. They are still excellent long life engines if respected. Keep the fuel delivery low at lower rpm’s and keep it in the upper rpm range when pulling. The old rule of thumb was 80% of max rpm.
s2mikon is offline   Reply With Quote
