Old 12-12-2022, 02:39 PM   #1
MemphisOrion's Avatar
Year: 1994
Coachwork: Orion
Chassis: Orion II
Engine: International 4600 7.3
Heard the Click
The constant wire is not giving me 12v, so I ran the wire from the battery to the ignition side and it clicks?
https://www.youtube.com/shorts/3jcP7FD_aBE
MemphisOrion is offline   Reply With Quote
Old 12-14-2022, 04:42 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i cant help with what triggers your glow plug or glow plug relay.
guess ignition switch.
i had an excavator that had a bad glow plug wire in the turn table area (bad design) so we ran a switched hot wire directly from the battery and had to count manually the 15 seconds on and then start.
timing might be longer for you but that is always an option to get going.
fix the problem and keep it as a back up.
just an idea.
