Old 01-11-2021, 03:23 PM   #1
Coachwork: Ford
Chassis: F350 Super Duty
Engine: T444E, 7.3
Rated Cap: 11,000lbs
Help me please somebody!
When I tell you what kind of "bus" that I need help with, I would like to state that there isn't a forum for half bread, or mutated vehicles that im aware of. And since "it" is built out of mostly school bus parts, here we go.
I have a 1995 F350 Super Duty one ton that used to earn it's grit from a power company here in Florida that I use as a service truck/equipment hauler. It has a reman 7.3, and is a real heavy duty truck all the way around. I lost my second zf 5 speed, and replaced it with a 545 Allison. It does pretty good considering. I need a new flexplate, and as you all know, you have to have a serial number for the boys at IHC to even think about finding your part. Can anyone out there supply me with a GOOD part number, or even the last 8 vin numbers for a bus that was dressed out with the same engine/tranny combo so I can fix my truck and get back to work before a go broke? I would even be willing to buy an old used one if one of you guys could turn loose of one.
Any help would be greatly appreciated.
Thanks
Chaos0812 is offline   Reply With Quote
Old 01-11-2021, 03:28 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i just sent you a response on your other/similar thread and hope it helps.
try to stick with one when responding so as not to drive you and us crazy but you will get responses on both.
you can ask the moderators to delete one if you want
7.3, allison 545, international
