Old 04-06-2020, 10:55 AM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
hi-beam headlight questions (2003 Amtran / IC 3800)
I think we have a problem with our headlights, but first I need to make sure I know how to operate them.
Right now, the low-beams work fine, and if you pull the multi-function (turn signal) switch lever towards you, the high-beams come on for as long as you hold it back, but they'll go back to low-beams as soon as you let it go & spring pressure returns it to its default position.
I know on some vehicles pushing this lever forward locks on the high-beams, and pulling it back only flashes them momentarily. But there does not appear to be a forward position. Am I correct in assuming the way to switch between high & low beams is to toggle between them by pulling back on the lever? All I should have to do is pull back & release to switch from low to high, or high to low, right?
If I'm right so far, is it some special sort of relay that controls this switching?
Go away. 'Baitin.
Our Build: Mr. Beefy
