Old 03-28-2024, 05:12 PM   #1
Coachwork: SS-17 3700
Chassis: 3700 short bus
Engine: IHC 7.3 A170
Rated Cap: 21500
jacking the bus question
The next question is what is best location to jack the rear of the bus. I did some searching, there is a lot of answers on blocking but could not find much on jacking.
I have a 24' International 3700 bus. 12,500 empty weight. Can I jack the bus using the point where the leaf springs attach to the axle?
I picked up some 6 ton jack stands and an air over hydraulic bottle jack.
To jack on the frame would require lots of height under the jack stands and jack.
Thanks
Joe
jpitz31 is offline   Reply With Quote
Old 03-28-2024, 06:51 PM   #2
fo4imtippin's Avatar
Chassis: TC2000 28ft
Depends what you are doing. I have lifted by the spring, and the frame above the spring, and the axle. I don't know that I would do it directly by the spring hanger, but depends on the situation.
Old 03-28-2024, 07:30 PM   #3
Engine: T444E, Allison 2000
I have jacked my bus up at the rear with just a bottle jack on the bottom diff u-bolt saddle.
Do NOT do it on the housing itself. I've seen it push through the housings......on loaded trucks. I hate the thought of lifting it on an empty truck.
CHAWK your WHEELS
Omnibot2000 is offline   Reply With Quote
Old 03-28-2024, 08:45 PM   #4
Rated Cap: 21500
Thanks all, I am jacking to pull the axle to check the number of teeth on the spline, and then later to do the brakes and replace a tire.
Looks like some 4 "x 6"'s are in order.
Old 03-28-2024, 10:12 PM   #5
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Jpitz
call me please. i will send pictures of the stuff i use. 7852077600
william
yea you can even call late tonight
Old 03-28-2024, 10:14 PM   #6
Year: 1954
Coachwork: wayne
hey
you dont need to kack up the rear to pull axles!!!!
you can do it with tires one the ground.
Old 03-29-2024, 12:18 PM   #7
Rated Cap: 21500
Thanks William I will try that.
Joe
Old 04-01-2024, 10:06 PM   #8
Year: 1972
Coachwork: wayne
Chassis: international
Engine: 345
Exactly! Don't make more work than necessary.
shortbus4x4 is online now   Reply With Quote
Old 04-02-2024, 07:25 PM   #9
Jesussaves's Avatar
Year: 2011
Coachwork: Collins
Chassis: Chey express 3500
Engine: 6.0
Thanks
Joe
I always go under the axle, never the frame.
Jesussaves is offline   Reply With Quote
jack stands, jacking, jacks
