Old 02-25-2020, 05:44 PM   #1
Long shot- Does anyone have a a good Allison 3060 CIN# for the DT466E?
Kinda stuck here, but basically the previous owner swapped out a manual transmission for A Allison 3060 out of a bus. Problem was we believe it was not a 466 bus as transmission shift points are clearly wrong. Talked to my local Allison dealer, and basically if he has to go to Allison for one he said it could be a issue because its a conversion. He said if I can find a CIN # he could download it from the Allison library. I know its a long shot but I thought I would try thanks in advance.
The CIN# is found on the label on the transmission ECU.
korgae is offline   Reply With Quote
Old 02-25-2020, 05:48 PM   #2
I believe somewhere in this thread is the contact info for some qualified non-factory-allison techs. who could program the xmsn however you want and unlock the 6th gear.
https://www.skoolie.net/forums/f10/a...ial-21661.html
David
The Murder Bus
Old 03-14-2020, 12:35 PM   #3
Can you provide the last 8 digits of your vin? If so, I'll see if I can find any info from a similar bus that was built that trans.
More Power is offline   Reply With Quote
