Old 06-25-2020, 07:16 PM   #1
Looking for a service manual
Anyone have a source for a service manual for a 2009 International Navistar DT466 engine and wiring diagrams, fuse panel for the 2010 RE 300 bus it’s in?
Local International dealer couldn’t help...if you can believe that.
Any help is much appreciated!!
LightlySalted is offline   Reply With Quote
Old 06-29-2020, 05:49 PM   #2
Chassis: RE300
Rated Cap: 76
PM me and I'll send you what I've got!
jjaj823 is offline   Reply With Quote
Old 07-03-2020, 01:10 AM   #3
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Chassis: IC FE 9 Window
Rated Cap: 29850
Actually I am looking for the same for my 2006 (w/2004 engine) FE300. Although I am getting good at "fuse guessing".
PeteinSF is offline   Reply With Quote
Old 07-03-2020, 08:04 AM   #4
Chassis: RE300
Rated Cap: 76
I have an RE300...try this:
https://www.dropbox.com/sh/yqlcj5g9r...NTMISCOPES.zip
If that doesn't have what you need, PM me as I might have some other stuff.
Old 07-09-2020, 12:42 PM   #5
jjaj832,
By chance do you have more on the DT466E?
I see most of your manuals are for the DT466.
That being said, maybe I don't know enough but aside from the electric injection, are they the same (466 & 466E)?
FijiWiji is offline   Reply With Quote
Old 07-09-2020, 01:38 PM   #6
Chassis: RE300
Rated Cap: 76
Originally Posted by FijiWiji View Post
jjaj832,
For the pre-2004 DT466E, use the following:
Service Manual: EGES-210-1
Diagnosis & Troubleshooting: EGES-270
For 2004 & Up use the following:
Service Manual: EGES-265-1 or EGES-265-2 (depends on engine S/N)
Diagnosis & Troubleshooting: EHES-270-1
Hope that helps!
Old 01-28-2021, 09:04 PM   #7
Would anyone happen to have service manual for 96 Amtran Genesis FE DT466? We are really needing info about the cooling system particularly. Thanks in advance!
BUSLIFE4US is offline   Reply With Quote
Old 01-28-2021, 09:10 PM   #8
s2mikon's Avatar
Engine: Cummins 8.3
Does this forum have a place for service manual files? I am on some 2 way radio forums and we have a place for just that.
s2mikon is offline   Reply With Quote
Old 01-31-2021, 12:14 PM   #9
Chassis: Vista 3600
Rated Cap: 24000 lbs
I have the leccy manual for the RE/FE buses year models 2000 - 2004
If you want it PM me your email address and I will send it
I also have the full T444E engine manual
in PDF form
it is wise to put them on a USB stick and take them to a kinko's and they will print AND bind it into a "book" for pretty cheap... then you have a hard copy in your kit for when you are stranded in the boonies without access to youtubes and the googles
RolesvilleMarina is offline   Reply With Quote
Old 01-31-2021, 01:00 PM   #10
Thanks for the reply! Do you know if there was much change from 1996 to 2000? Bus was built 12/1995
Old 02-02-2021, 12:47 PM   #11
Chassis: Vista 3600
A lot of stuff was the same kinda
I used the 2002 leccy manual as a reference and I was working on my 1999 bus
maybe some differences but IH was lazy and shite about wiring, and the entire company since the scout days has just not been keen on fixing it if "it ain't broke"
newer buses still have 1950's style wiring lol... it's just an IH thing
Old 02-02-2021, 02:03 PM   #12
ewo1's Avatar
here is a dt466e complete service manual but...it is in spanish...at least the words are...
Pictures are in english...lol
http://diagramas.diagramasde.com/otr...6_&_i530E_.pdf
Old 04-18-2021, 08:02 AM   #13
Engine: Dt 466, navistar
Hi...would you happen to have a service Manuel fo a 2001 international, navistar dt466. Thank you so much
Annita808 is offline   Reply With Quote
Old 04-18-2021, 08:13 AM   #14
ewo1's Avatar
Search button....it can perform miracles !
https://www.skoolie.net/forums/f37/d...ual-35598.html
Old 04-18-2021, 08:39 AM   #15
Thanks! Definitely downloaded. Totally better to have something then nothing Plenty of resources out there to translate! My husband and I had a good laugh about your post lol!
Old 04-18-2021, 10:13 AM   #16
ewo1's Avatar
glad you got it.
I had saw another post where someone was making all the manuals available for $250 dollars. Not bad if a) you got the spare coin, b) you can't get the info anywhere else.
Well that post set me off on a mission to find what I could and find a way to share it.
Oh and by the way, help us all out and fill out your user profile that way we all will know what kind of bus you have....
Many of the sources I found the files are to big to upload here so I just shared the link instead, for free..
I would download and save to a flash drive any and all manuals anybody posts cause one day they may not be available, or at least when you need it most!
One more thing, here is the link for that engine manual in INGLES !!!
DT466 and 530, 2000 year and up
http://docs.diesel-data.com/Heavy%20...(EGES2101).pdf
Old 04-18-2021, 02:36 PM   #17
Any have anything for a CAT 3116, or a 95 Thomas saf-t-liner?
Cheezewhiz is offline   Reply With Quote
Old 04-18-2021, 02:52 PM   #18
ewo1's Avatar
Cat/ saf t liner manual
As I mentioned earlier; the search button is your friend !
https://www.skoolie.net/forums/f33/i...ses-10745.html
And here is a maintenance manual to boot!
https://dtnacontent-dtna.prd.freight...ce-manual.html
On the 3116 of which I know nothing about, I was very impressed with a YouTube channel by adept ape
https://youtu.be/6zAmgiI7Kog
Old 04-18-2021, 03:36 PM   #19
Close, but no cigar!
I already found that google doc dump, and saved it all just in case, but none of it actually matches my bus. Womp womp
Wish the original directory was still up, I'd love to have seen what else was in there
Old 04-20-2021, 08:24 AM   #20
ewo1's Avatar
You sent me off on a mission and I uploaded a few 3126 service manauls for ya...
https://www.skoolie.net/forums/f38/c...tml#post435303
