Before you contemplate releasing the air in your suspension, you may want to place the bus on jacks or jackstands first. When you release the air from the bags the suspension will collapse. If you are in the wrong place under the bus it may trap you in there, or worse maybe squish you.
I have worked on my air ride in the "new Crown" and found things can move quickly underneath.
