Originally Posted by Dead pirate
No VIM on this bus. It has a large fuse/relay box. Grey connector tcm. Pin 28 is yellow and .08 volts give or take. Pin 26 is pinkishgrey. I need a pin out for this vehicle. The one online is for a vehicle with VIM. Cannot locate the right one. Id like complete pinouts for ecm tcm valve body and digital shift box. Can you help? Attachment 51901
Your bus DOES have a vim... it is the big black box in the rear engine compartment, where the rear key switch is...that is the vim!
Have you tried starting it from rear rear key switch???
Not too long ago, 3-5 months ago, there was a post where a guy could start his bus from the back and not the front. He had found a burnt diode that is nested inside the vim within the front/rear key switch circuitry.
If your bus is starting via the way you jumped it at leAst the ecm is functioning.
The TCM should be sandwiched between the tranny and bus frame, at least on my bus it is, a 99 RE Amtrak.
