Old 12-13-2020, 06:31 PM   #21
ewo1's Avatar
Originally Posted by Dead pirate View Post
No VIM on this bus. It has a large fuse/relay box. Grey connector tcm. Pin 28 is yellow and .08 volts give or take. Pin 26 is pinkishgrey. I need a pin out for this vehicle. The one online is for a vehicle with VIM. Cannot locate the right one. Id like complete pinouts for ecm tcm valve body and digital shift box. Can you help?Attachment 51901
Your bus DOES have a vim... it is the big black box in the rear engine compartment, where the rear key switch is...that is the vim!
Have you tried starting it from rear rear key switch???
Not too long ago, 3-5 months ago, there was a post where a guy could start his bus from the back and not the front. He had found a burnt diode that is nested inside the vim within the front/rear key switch circuitry.
If your bus is starting via the way you jumped it at leAst the ecm is functioning.
The TCM should be sandwiched between the tranny and bus frame, at least on my bus it is, a 99 RE Amtrak.
Old 12-13-2020, 06:34 PM   #22
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
I got it to start. Im tracing wires from the tcm . im trying to get a pin out for the tranny shift pad. Its a ahort some where
Dead pirate is offline   Reply With Quote
Old 12-13-2020, 06:34 PM   #23
ewo1's Avatar
Wreck 3 troubleshooting
Follow this guys troubleshooting steps... it is spot on !!!!
https://www.transmissioninstruments.com/wteciii/
Old 12-13-2020, 06:39 PM   #24
ewo1's Avatar
It’s not a short...with a short you would blow a fuse or burn some wires.
It is more likely and “open” wire somewhere, probably broken at a connector or some other stress point along the run.
Follow these instructions, you can’t go wrong.
Also. Look at the attachments on post #3.
https://www.skoolie.net/forums/f33/m...nel-24837.html
Old 12-13-2020, 06:44 PM   #25
Coachwork: myself
Chassis: amtran
Maybe my initial attempts were flawed. Im gonna regroup and try this in the morning. That test light thing looks like might help. I have to tow it from the non 24hr. Walmart.
Old 12-13-2020, 06:50 PM   #26
ewo1's Avatar
If you call the guy at transmission instruments, he is very helpful and friendly !
Old 12-13-2020, 07:13 PM   #27
I dont know if these help or not.. they are what I have .. they are on a windows machine and im on a MAC.. you cant print these to PDF.. they are in a propreitary IE format so i just had to screen capture them.
Name:	Screen Shot 2020-12-13 at 8.08.42 PM.png
Name:	Screen Shot 2020-12-13 at 8.08.18 PM.png
Name:	Screen Shot 2020-12-13 at 8.07.49 PM.png
Name:	Screen Shot 2020-12-13 at 8.07.13 PM.png
Name:	Screen Shot 2020-12-13 at 8.06.25 PM.jpg
Name:	Screen Shot 2020-12-13 at 8.05.57 PM.png
Name:	Screen Shot 2020-12-13 at 8.04.41 PM.png
Old 12-14-2020, 07:52 AM   #28
ewo1's Avatar
Here are some diagrams from my previous troubleshooting work...
Old 12-14-2020, 07:55 AM   #29
ewo1's Avatar
And here is the VIM wiring diagrams..
I also included the diode assembly I spoke about earlier.
The diode assembly, only have to look at that if your bus starts from one end but not the other.
I do not believe it has anything to do with the dark push pad panel but hey, I am not a mechanic!
I also added a pic of what went bad in my bus, a broken wire inside one of the connectors next to the tranny.
This is why I suggested to unplug the connectors, do a visual inspection and then re-seat the connector. The pin itself had broken apart, inside the connector housing!
That was how I found my broken wire.
Old 12-14-2020, 07:59 AM   #30
NICE diagrams!! easier to read than the stuff navistar puts out on their 'OnCommand' tool
Old 12-14-2020, 08:06 AM   #31
ewo1's Avatar
Thanks...
Next time you come down to Ft Lauderdale let's meet up!
Lunch (liquid) will be on me!
Ed..
Old 12-14-2020, 09:03 AM   #32
Coachwork: myself
Chassis: amtran
Those are close but not right. 26 is 27. Its yellow and its a ground. It is supposed to be 5 or 12v i don't remember right now. That would indicate the tcm is fried but not being sure ( because the diagram is different) i cant say.
Ill xheck these new pinouts and see if its correct
Old 12-14-2020, 09:05 AM   #33
Coachwork: myself
Chassis: amtran
Im in daytona beach. Do you know anyone that works on these? Non commercial.
Old 12-14-2020, 10:50 AM   #34
ewo1's Avatar
I just sent you a PM with my number, give me a call.
