doesnt have the part number of the ECU itself.. but does show you that the calibration you need is for 2400 RPM and auto-detect throttle type.. (I dont know how your bus is wiored up for throttle,.. since its a 466E I can assume they have it connected to the J1939 link which is a 3 pin WeatherPak connector coming off the engine computer with a yellow,black, and green wire.. if that connector is plugged in and going off somewhere then you can use a TCM with throttle type J1939, if that connector is just capped off then navistar used a different throttle method and your new TCM will also need to be Autodetect. im not sure on a flat nose bus where that connector is. usually near the engine.. im assuming its for the bus listed in your profile as a 466E. it *looks* like you have WTEC III TCM but I can see so very little of it in the pic its hard to tell for sure..
